Wipers do not work properly - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 8th, 10, 04:44 PM Thread Starter
ern
ern
Exclamation Wipers do not work properly
i have a 69 camaro with wipers that when i turn off the switch will sometimes stop where ever they want or sometimes they will park but they also seem to want to go down before they go up. just got the car have not had time to remove the motor to see if the proper arm is on the motor. any hints would be great
ern is offline
post #2 of 9 (permalink) Old Mar 8th, 10, 07:09 PM
Kevin
KevinW's Avatar
Re: wipers do not work properly
Ern, this is a common problem. The parking circuit is handled by a ground at the upper most grommet, there is a brass ring grounding the base of the motor through the grommet and screw to the firewall. If you dont have a good ground there, the park will not work. Unscrew that screw and clean the grommet and brass ring. Once it parks consistantly, realign wiper arms by taking them off when parked and installing them even with the lower molding.
Kevin
KevinW is offline
post #3 of 9 (permalink) Old Mar 8th, 10, 09:41 PM
Steps
That is the most common issue, espec after a repaint
The other is the arms have been bent out of wack slightly
Steptoe is offline
post #4 of 9 (permalink) Old Mar 9th, 10, 08:19 AM Thread Starter
ern
ern
thanks much for the hints will let you know and hope to post picture of car soon as i figure out how to do theat
ern is offline
post #5 of 9 (permalink) Old Mar 9th, 10, 03:54 PM Thread Starter
ern
ern
i tryed a jumper wire to the motor no change. in seems like the motor parks half way through its sweep then it goes up and the wipers go down to far . do you still think is a ground problem. when it parks the rod on the motor is straight down looking through te cowl. any ideas thanks
ern is offline
post #6 of 9 (permalink) Old Mar 9th, 10, 04:44 PM
Kevin
KevinW's Avatar
Ern, the motor arm should be pointing halfway to the drivers side. When you let the wipers run for a couple of swipes and then turn them off what happens? Just stops or moves a little more? the wiper transmission might not be installed correctly.
Kevin
KevinW is offline
post #7 of 9 (permalink) Old Mar 10th, 10, 06:58 PM Thread Starter
ern
ern
hi kevin, the arm usually parks at the same spot at 6 oclock, sometimes they just stop but when it does park it is straight down. could it have the wrong arm on it or could it be on back words. i,m off next week plane to take motor off and have a look .thanks again for your help
ern is offline
post #8 of 9 (permalink) Old Mar 18th, 10, 05:15 PM Thread Starter
ern
ern
Re: Wipers do not work properly
to redlinesarus and kevin ,found a post that was in the archieves, had same trouble ,it end up being the wiper motor crank arm was the wrong one , put the new one on all is well ,now if i can get the headlight doors to work thats the last battle, tremic and 3.55,s go in next week spring is coming .thanks again for all the help ern
ern is offline
post #9 of 9 (permalink) Old Apr 14th, 10, 05:39 PM Thread Starter
ern
ern
hi all tremic is in and gears are done, car works great don,t like the shifter, mccloud off set, have ordered hurst billet 2, will let you know how it is
ern is offline
