Drive train vibration - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 8th, 10, 10:43 PM Thread Starter
Hi, I have a 68 350 with power-glide, it appears to have a vibration coming from the rear of the car at around 65mph and upwards under load, it sends a vibe right thru the car, is it likely that its the transmission or drive shaft, any clues please?
robosanta3 is offline
post #2 of 6 (permalink) Old Mar 9th, 10, 04:37 AM
Harry
dawg's Avatar
Re: Drive train vibration
first I would have wheels balanced.
a thrown wheel weight would cause that vibration.
Does the vibration happen when the car is in park or neutral?
Also a bent wheel can cause vibrations too!
434 stroker
US Navy retired
dawg is offline
post #3 of 6 (permalink) Old Mar 9th, 10, 02:58 PM Thread Starter
I'm starting to think its the drive shaft or universal joint, round the streets it ok, its more when you get speed up on the highway 55mph +
post #4 of 6 (permalink) Old Mar 9th, 10, 05:42 PM
Steiner
Mine did that when the driveshaft tube somehow got dented. It would make your eyes go fuzzy at 70mph. I recently got one shortened, balanced, and new front u-joint installed for $45. Just pop the two straps off the pinion and pull the whole thing out of the transmission.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 6 (permalink) Old Mar 10th, 10, 11:57 AM Thread Starter
Cheers, I think it is the drive shaft will look further into that.
post #6 of 6 (permalink) Old Mar 10th, 10, 02:49 PM
Gary
TraxUnderground's Avatar
look at the rear pinion angle. Caused me alot of grief. Alot of posts about it. Search pinion angle if you cant find a wheel balance of drive shaft issue.
Gary
67 RS Resto-Mod 468 5 spd TKO600 3.73 12 bolt (work in progress but finally on the road!)
73 Camaro project in a million pieces
TraxUnderground is offline
