Another fuel gauge problem!!! - Team Camaro Tech
post #1 of 14 (permalink) Old Mar 12th, 10, 03:56 PM Thread Starter
I have Auto Meter gauges, 0 ohms at sender (tank empty), 0 ohms at wire going to S terminal of gauge, ground from gauge and sender body. But my gauge reads past full. Help!
67S/S is offline
post #2 of 14 (permalink) Old Mar 13th, 10, 06:19 AM
Re: Another fuel gauge problem!!!
Reverse leads on gauge.
post #3 of 14 (permalink) Old Mar 13th, 10, 08:39 AM Thread Starter
Tried that and the gauge reads the same-past full.
67S/S is offline
post #4 of 14 (permalink) Old Mar 13th, 10, 09:17 AM
Harry
dawg's Avatar
I learned that a past full reading is a ground problem.
find another ground.
434 stroker
US Navy retired
dawg is offline
post #5 of 14 (permalink) Old Mar 13th, 10, 09:36 AM
mike
Re:electric problem 68
i would like to know what wirer hooks onto back of fuel gauge,also i problems with high beam indicator,i have ground strap,high beam light socket with wirer but socket has to turn in or get fixed to cluster some how,help also brown wirer coming off of fuse block inside with conector on it what or where does it go
camaro58503 is offline
post #6 of 14 (permalink) Old Mar 13th, 10, 11:28 AM Thread Starter
Dawg-would you think the ground at the sender or at the gauge.
67S/S is offline
post #7 of 14 (permalink) Old Mar 13th, 10, 11:51 AM
The ground at the sender. You should be able to read some ohms/continuity from the wire going to the sending unit through the body harness to ground with the wire unhooked from the gauge.
Oh, you've done this in Post 1. Do you have original gauge to test the circuit?
post #8 of 14 (permalink) Old Mar 13th, 10, 12:30 PM Thread Starter
Yes I do, I'll try that. Let you know.
67S/S is offline
post #9 of 14 (permalink) Old Mar 13th, 10, 03:03 PM Thread Starter
Well hooked up the original gauge cluster and it reads correctly. Must be a bad gauge?
67S/S is offline
post #10 of 14 (permalink) Old Mar 13th, 10, 03:06 PM
Harry
dawg's Avatar
yes and I would call autometer they might replace the bad one
434 stroker
US Navy retired
dawg is offline
post #11 of 14 (permalink) Old Mar 13th, 10, 03:25 PM Thread Starter
Found the problem. The gauge was mis-boxed. Ordered part#1214 but #1217 was in package. 240ohms empty/33ohms full.
67S/S is offline
post #12 of 14 (permalink) Old Mar 13th, 10, 04:04 PM
Harry
dawg's Avatar
kinda azz backwards lol
434 stroker
US Navy retired
dawg is offline
post #13 of 14 (permalink) Old Mar 13th, 10, 08:26 PM
Good work in finding the problem!
Gauge for a Mopar.
post #14 of 14 (permalink) Old Mar 14th, 10, 05:53 AM
Harry
dawg's Avatar
EWWWW!!!!
you had a mopar part in your car??????
434 stroker
US Navy retired
dawg is offline
