Vaccuum Gauge Issues/ IDLE - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 17th, 10, 05:24 PM Thread Starter
Kip
What would cause the needle of a vacuum gauge to shake violently between 9"an 14" at 1000rpm. This is on a 350. 15* initial, 34* total, with vacuum advance not hooked up...
The engine idles rough too.... I have been having a heck of a time getting this freak'n thing to run like I think it should... and I am starting to wonder if it is not an internal issue.
Any info on the vacuum gauge issue would be appreciated...
Kip.....
kv67ssrs is offline
post #2 of 13 (permalink) Old Mar 17th, 10, 05:25 PM
Skip
Skeeter55's Avatar
Re: Vaccuum Gauge Issues/ IDLE
When this happens could it be a draw from electric fans kicking on... Also when the vacuum drops dose the rpm drop to.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 13 (permalink) Old Mar 17th, 10, 05:27 PM
Steiner
http://www.centuryperformance.com/tu...e-spg-148.html
http://www.tuningmadeeasy.com/tuning...e-wonder-tool/
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 13 (permalink) Old Mar 17th, 10, 05:37 PM
Fred
Not good. When exploring the above links, pay attention to the part about bad valves. Also run a compression check. Also be planning your tear down. Oh, IMHO or course.
128.79mph 1.428 60'
Fred Ficarra is offline
post #5 of 13 (permalink) Old Mar 17th, 10, 05:43 PM
Skip
Skeeter55's Avatar
Nice links Steiner
post #6 of 13 (permalink) Old Mar 17th, 10, 05:56 PM
Steiner
Originally Posted by Skeeter55 View Post
Nice links Steiner
Thanks. Can you tell I've had a set of heads rebuilt? Ha ha.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 13 (permalink) Old Mar 17th, 10, 06:41 PM Thread Starter
Kip
I was kinda afraid that it was a bigger issue that just idle mixture screws or timing...
The engine came with the car... and I really have kinda been suspecting its soundness... But, I didnt buy the car for the engine...
Are we talking head issues or or complete rebuild...?
kv67ssrs is offline
post #8 of 13 (permalink) Old Mar 17th, 10, 06:55 PM
I'd start simple. Could be that someone over tightened a rocker arm causing a valve to hang open. A compression test is a good first step also.
dnult is offline
post #9 of 13 (permalink) Old Mar 18th, 10, 05:56 AM Thread Starter
Kip
Great links... I am gonna do a compression test and also maybe take a look at how I have the wires from my MSD system routed... Thanks for the responses...
kv67ssrs is offline
post #10 of 13 (permalink) Old Mar 18th, 10, 04:37 PM
Steps
This is the most common reason espec on a new engine/head...set cold before 1st start up.....they always need rechecking and again a few 100 miles on the clock...
Steptoe is offline
post #11 of 13 (permalink) Old Mar 18th, 10, 06:19 PM Thread Starter
Kip
This is an old engine... that came with the car. Its a 69 block, that was rebuilt about 10 years ago with pretty good parts...
I moved the MSD system and routed all of the wires away from each other... Still doing strange things on the vacuum gauge. Today, I ran the motor up to about 2500rmp. Vacuum went up to about 20" and the needle steadied out.... Previous links in this thread are pointing me to worn valve guides.....
kv67ssrs is offline
post #12 of 13 (permalink) Old Mar 18th, 10, 09:03 PM
Steps
Worn Valve guides 2 ways to check
1/mark which way the plugs sit in the block pull them out black on to giudes black on the bottom rings
2/ after engine has beenm sitting , usually needs to cool down for slightly worn ..fire up and a big puff of smoke out the rear
Guides have to be really really bad to get the effect you mention and they dont show wear till around 100K to 120,000 miles and run like that up around 180,000 miles nps.
Steptoe is offline
post #13 of 13 (permalink) Old Mar 18th, 10, 10:12 PM
hook up the vacuum advance to a full manifold vacuum, and adjust the idle speed down to compensate for it.
then play with the idle mixture screws.
if that doesn't work, pop the valve covers and readjust the valves- if it has a hydraulic cam, do it with the engine running. then play with the idle screws again.
if that fails, then there is something mechanical going on.
you don't plan sincerity.
novaderrik is offline
