starting problem - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 19th, 10, 02:55 PM Thread Starter
jason
Question starting problem
i bought an 87 camaro with a 305 4 barrel. last night i drove it about 2 hrs straight to see family. it is the first time ive drove it that far at once. ran great. when i left started right up. stopped at a gas station before heading home for soda. came out and nothing. it was like it was still in drive ya know absolutely nothing from the starter. tried jumpin it just in case. nothing. so i got to go get a starter after being stranded all night. thought ill try the key just for giggles. fired right up. so i didnt miss a beat drove straight home and backed her in the drive. shut her down and tried to start back up but nothing. same as before no noise at all from the starter like it was left in drive or something. i tried starting in nuetral nothing. any ideas?
forevverlost is offline
post #2 of 6 (permalink) Old Mar 19th, 10, 03:21 PM
Re: starting problem
"heat soak" starter/solenoid can get hot.
john68 is offline
post #3 of 6 (permalink) Old Mar 19th, 10, 03:31 PM Thread Starter
jason
after a bit i got her started and after running for like ten mins i shut it down and restarted then after about another 10 mins i shut it off and the same thing. nothing like its in drive
post #4 of 6 (permalink) Old Mar 20th, 10, 10:16 AM
Derek
fuel isnt getting to the throttle body
my 91 z28 cut off yesterday and i cant figure out why? i have checked the computer so i know its not the injectors. i have been told to look into the fuel pump, fuel filter, clean throttle body, exhaust could be blocked. is there anything else i should look into?
91z28 is offline
post #5 of 6 (permalink) Old Mar 20th, 10, 10:26 AM
Derek
didnt mean to post the other message, but it could be the battery or the security chip. i had the same problem and cut the security wire and never had the problem again.
91z28 is offline
post #6 of 6 (permalink) Old Mar 21st, 10, 03:52 PM Thread Starter
jason
thnx for the info it was heat soak... replaced the starter and got a heat shield wrap for it no more problems
