Rear Disk Brake Rotors - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 19th, 10, 04:01 PM Thread Starter
Glenn
Angry Rear Disk Brake Rotors
OK guys, not a camaro but my daily driver. Trying to remove the rear disk rotors on my 2000 S-10 pickup ( 4wd 4.3 engine). Tryed penetrating oil-lots of heat from a torch- and my trusty big hammer-so far no luck. seems to be rusted on the axle flange. Any of you auto techs have ideas? Thanks in advance guys
lowbuck69x11 is offline
post #2 of 7 (permalink) Old Mar 19th, 10, 04:24 PM
Re: Rear Disk Brake Rotors
bigger hammer and swing it harder
69 Pace Car and 69 Hard top
srode is offline
post #3 of 7 (permalink) Old Mar 19th, 10, 06:31 PM
Andrew
Andrew69's Avatar
Does it have the internal parking brake and could the parking brake be set? Just guessing.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 7 (permalink) Old Mar 19th, 10, 06:42 PM Thread Starter
Glenn
Yes- It does have internal parking brake, but it has been released and adjustment nut on cable has been fully backed off. Have been using my biggest hammer & beating the crap out of it--still stuck.
post #5 of 7 (permalink) Old Apr 18th, 10, 03:29 PM
ern
ern
if there stuck that bad you will either have to cut them off or take the axles out and press them off. good luck
ern is offline
post #6 of 7 (permalink) Old Apr 18th, 10, 03:41 PM
Larry
larryh56's Avatar
Did you use PB Blaster? It's the best by FAR I have ever used.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #7 of 7 (permalink) Old Apr 18th, 10, 04:33 PM
Andrew
Andrew69's Avatar
Did you get 'em off?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
