Keeps running - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 21st, 10, 10:30 AM Thread Starter
Keeps running
79 350 motor auto trans Camaro. MSD dis and box box keeps running when I turn the key off,only sometime.to get the car to turn off turn the key on give it gas turn the key off than it would shut off only does it some times.Why is it doing this?
Rebel72 is offline
post #2 of 4 (permalink) Old Mar 21st, 10, 12:53 PM
Ron
Re: Keeps runiing
I don't know if you are describing Diesel Run-On or you saying the Coil is not De-Energizing when the Key is turned off.
Dieseling is caused by improper Carb Throttle Plate Position (Vacuum Leak Issues) and Timing; where as, a Live Coil after Key Turn of means you NOT killing power to the Coil which can be caused by Improper Wiring or possible that the Alternator is activating the Ignition Circuit upon shut down in which case you may have to put an Condenser from Alternator Out Put to Ground.
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 4 (permalink) Old Mar 21st, 10, 01:29 PM
Re: Keeps runiing
You might search for the keyword diode. I know MSD setups can suffer from a problem where they remain energized enough to back-feed the electical system. Installing a diode was a work around. You should also find info on the MSD website about it.
Don't overlook the possibility of a bad ignition switch or another wiring problem.
dnult is offline
post #4 of 4 (permalink) Old Mar 21st, 10, 02:25 PM
Ron
Re: Keeps runiing
Condenser
Should have said DIODE
Also a bad Diode in the Alternator's Rectifier Circuit can cause the Alternator to continue charging after the Key is turned off.
X's 2 on Faulty Ignition Switch.
Z15CAM is offline
