1991 Camaro PROBLEMS - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 22nd, 10, 01:38 PM Thread Starter
Eric
ok i have a 1991 camaro rs 3.1L v6
ok i have this problem with my camaro, my spark plugs are getting filed out and soaked with gas. and the engine dies, i replaced all spark plugs and it fires right back up, after a day or two the plugs go bad and engine wont crank again. so i replace them and it fires right up. and it sounds like it is not running on all cly. i dont know what the problem could be? can anyone help me. im thinking that it might be the fuel injectors, but i dont wanna throw that kinda money at it if its not that at all...
any ideas anyone?
hoodedmagic is offline
post #2 of 8 (permalink) Old Mar 22nd, 10, 04:14 PM
Re: 1991 Camaro PROBLEMS
Pull the vacuum line off the fuel pressure regulator and see if the nipple is wet with fuel. You may have a ruptured VR diaphram that is sucking raw fuel into the engine.
dnult is offline
post #3 of 8 (permalink) Old Mar 23rd, 10, 11:07 AM Thread Starter
Eric
ok where is the fuel pressure regulator located at?. .
post #4 of 8 (permalink) Old Mar 23rd, 10, 11:32 AM
BILL
SPARKY69's Avatar
On the fuel rail
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 8 (permalink) Old Mar 23rd, 10, 03:06 PM
Coolant sensor (for the comp)
john68 is offline
post #6 of 8 (permalink) Old Mar 23rd, 10, 09:38 PM Thread Starter
Eric
im sorry but what doe sthe coolant have to do with gas?
post #7 of 8 (permalink) Old Mar 24th, 10, 06:10 AM
If the computer thinks the engine is cold, it will give a lot of extra fuel.
john68 is offline
post #8 of 8 (permalink) Old Mar 24th, 10, 10:26 AM Thread Starter
Eric
ok thank you, i will take a look at these items and see if that is the problem.
