No Pwr at testpoint on PCM - Team Camaro Tech
post #1 of 28 (permalink) Old Mar 22nd, 10, 07:19 PM Thread Starter
Greg
what voltage should i have at testpoint of pcm for fuel pump. where does pump get power from pcm or from pump relay?
95camaroman is offline
post #2 of 28 (permalink) Old Mar 22nd, 10, 07:22 PM
Daryl
1968RallySport's Avatar
Re: no prw at testpoint on pcm
battery voltage. fuel pump gets voltage from fuel pump relay.
1968RallySport is offline
post #3 of 28 (permalink) Old Mar 23rd, 10, 03:12 AM
Usually, a relay will get battery power from a fusible link or fuse from a buss line applied to one wire of the relay coil, battery voltage.
The other relay coil wire is connected to the PCM and the PCM applies a 'low' to energize the relay, if measured to ground, about 0.5 volts.
Fuel pump relay closes the power contacts for the f/pump, battery voltage. This design transfers heavy current to the relay contacts.
post #4 of 28 (permalink) Old Mar 23rd, 10, 04:36 AM Thread Starter
Greg
I have no pwr at testpoint. if i jumper pwr to test point pump runs. Ive jumpered pump relay and pump wont run. not sure if pcm is problem or something else I should be looking at? Help.
post #5 of 28 (permalink) Old Mar 23rd, 10, 06:10 AM Thread Starter
Greg
I have an intermittant problem. worked on car yesterday no pwr at test point. jumped pump relay pump wouldnt run. today 12v at test point. pump runs. I now have 2 pumps and 3 relays (got a pump and 2 spare relays at yard yesterday) all work today. Do you think my intermittant problem is from pcm? I have read something about ignitionkey possibly messed up. any ideas. My son got license couple days ago this is killing him.
post #6 of 28 (permalink) Old Mar 23rd, 10, 06:23 AM
Re: No Pwr at testpoint on PCM
No power at test point, could be an open fusible link or blown fuse before the test point.
post #7 of 28 (permalink) Old Mar 23rd, 10, 09:34 AM Thread Starter
Greg
no blown fuse/open link intermittant problem. had 12v this morning, .o5v now.pump was running relays were functioning, had pwr back to pump car would drive. now lost 12v at test point,and pump.
post #8 of 28 (permalink) Old Mar 23rd, 10, 10:08 AM
Car have VATS?
Do you have a service manual, at least a Haynes?
There has to be a device between battery and f/pump relay not doing its function.
post #9 of 28 (permalink) Old Mar 23rd, 10, 01:55 PM Thread Starter
Greg
not sure what vats is. no service manual, do you think it can be computer going bad?
post #10 of 28 (permalink) Old Mar 23rd, 10, 01:59 PM
Yes he has VATS, The pellet in the key,
john68 is offline
post #11 of 28 (permalink) Old Mar 23rd, 10, 02:16 PM Thread Starter
Greg
thanks john68 I wasnt sure what vats was. Any ideals what problem may be. Could it be key or maybe pcm?
post #12 of 28 (permalink) Old Mar 23rd, 10, 04:36 PM
If the starter turns when commanded by the key/ign, then VATS is not the problem.
VATS = Vehicle Anti-Theft System
To find electrical source to test point, at least a Haynes manual should be acquired. It'll help you out in times like this one - nothing like having a road map for the electrical system.
Another method of powering the f/pump relay is the PCM applying battery voltage to the coil and the other wire of the coil going to ground to complete the circuit. If the circuitry is this method, then yes, it could be the PCM, but aleviating other inputs to the PCM should be done first.
You should hear the f/pump buzz for 2-3 seconds when key goes to IGN and with 30 seconds in between turn ON times.
post #13 of 28 (permalink) Old Mar 23rd, 10, 04:46 PM Thread Starter
Greg
not key car turns over fine. not pcm just got one from yard no change. no pwr to test point no pwr to pump. about 14v at red wire on relay have jumped several times. sometime pwr get to pump sometimes no pwr to pump. I work midnights im going to get manual on way to work about 20 miles to store so gonna have to wait till tonight. I cant figure out why I have pwr to relay but not back to pump. sometimes there sometimes not there. 3 relays and just a hot wire jumper and I get same intermittant symptoms at the pump..
post #14 of 28 (permalink) Old Mar 23rd, 10, 04:50 PM Thread Starter
Greg
I have looked at conector /harness going through floor to pump not sure what I should have on the three prongs but the connector looks fine. not burnt looking no chaffed or cut wiring.
post #15 of 28 (permalink) Old Mar 23rd, 10, 04:58 PM
If you have pulled the relay and jumpered the socket to get power to the f/pump and it works sometimes and not, could be the pump itself or wiring. maybe unplugging and plugging the connector might help.
Next time the f/pump does not work, bang the tank to jump start the pump. One of the wires would be the same red wire from relay socket. If jumpered, you should have power there at tank. Another wire, if black, would be ground. Could be the terminal of this wire at body is heavily corroded and not making good contact to complete the circuit. The last wire, tan?, would be for fuel gauge.
