RPMs wont go down after hitting the throttle at idle - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 27th, 10, 01:52 PM Thread Starter
New 350 290 hp crate motor, new fuel pump, new HEI, used Edelbrock carb. It started right up, idled nice, set the timing at 10 degrees, set thye idle but when I blipped the throttle, it went up to 1800 rpms. It keeps doing this and I cant figure it out. Put on new vacuum lines. Checked for vacuum leaks, checked for correct carb gasket, checked for throttle linkage binds, checked auto choke wires, etc. Any thoughts? The carb worked fine when I took out the engine.
wheezer is offline
post #2 of 13 (permalink) Old Mar 27th, 10, 02:25 PM
Re: rpms wont go down after hitting the throttle at idle
Check the timing advance with a timing light. Sounds like the mechanical advance may be kicking in too soon and once you reach that point, the RPMS increase. Do you have vacuum advance on this engine?
dnult is offline
post #3 of 13 (permalink) Old Mar 27th, 10, 02:39 PM
Harley
wiskeesour's Avatar
linkage is hanging either at the carb or in the floor or where the linkage comes thru the floor to the carb.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #4 of 13 (permalink) Old Mar 27th, 10, 03:17 PM Thread Starter
the rpms go up whether I hit the pedal or take the pedal linkage off and hit the carb throttle. The distributor (new) has a vacuum canister but ive put the line in both ports (one full vacuum and one ported), with no difference. Not sure its a vacuum problem as a sprayed carb cleaner everywhere with no change in rpms. If I push down hard on the carb throttle the rpms slow down but as soon as a blip it, up again.
wheezer is offline
post #5 of 13 (permalink) Old Mar 27th, 10, 03:54 PM
Try another carb as the throttle plates are rubbing against the bore.
Everett#2390 is online now
post #6 of 13 (permalink) Old Mar 27th, 10, 04:20 PM
Skip
Skeeter55's Avatar
X2 Internal vacuum leak causing the idle to fluctuate. Also check for any unplugged or cracked vacuum lines or intake leak.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #7 of 13 (permalink) Old Mar 27th, 10, 05:32 PM
Harley
wiskeesour's Avatar
alright, have you checked your air bleeds?
Thanks Chief.
post #8 of 13 (permalink) Old Mar 27th, 10, 07:38 PM
Steps
Re: RPMs wont go down after hitting the throttle at idle
Secondaiys mis ajusted or mislalgned, or to much play/wear in the butterfly bushs
Steptoe is offline
post #9 of 13 (permalink) Old Mar 28th, 10, 09:08 AM
Here's another thought. Carberators have choke mechanisms on them. When the engine is cold, the choke plate closes to make the motor run rich. In addition, a little stepped cam under the choke housing is suppose to raise the idle speed. It's called the fast idle cam. It's weighted so it will fall down away from the fast idle stop screw. When the engine is cold, the choke spring pulls it up and essentially engages another idle stop setting - the fast idle setting.
If the choke is not properly set up, you could be having problems with the fast idle cam. Also, on my Holley, I had problems initally with linkages binding up and preventing the fast idle cam from dropping away from the fast idle stop. Usually you can diagnose this quickly by partially cracking the throttle by hand to lift the primary throttle shaft off the fast idle stop. Then manually open the choke plates wide open. This *should* force the fast idle cam to drop. Let go of the throttle shaft so that it sets on the curb idle screw - it should idle normally then. Of course if the choke linkages aren't correct, or some other alignment problem exists, this last quick test may not work.
dnult is offline
post #10 of 13 (permalink) Old Mar 28th, 10, 12:07 PM
Steps
I keep forgetting about the choke...most of the classics here we remove the chokes as we dont have the cold temps most of you guys have.
Steptoe is offline
post #11 of 13 (permalink) Old Mar 29th, 10, 05:01 AM Thread Starter
Thanks. Dont know what is wrong with the carb but it was the carb (got another carb and it ran fine).
wheezer is offline
post #12 of 13 (permalink) Old Mar 29th, 10, 07:09 AM
Skip
Skeeter55's Avatar
Originally Posted by wheezer View Post
Thanks. Don't know what is wrong with the carb but it was the carb (got another carb and it ran fine).
Nice job and thanks for the update.. Ive had a carb giving me the same problem "internal vacuum leak" don't know from what maybe just old ware and tare.
post #13 of 13 (permalink) Old Mar 30th, 10, 11:21 AM
Fred
And maybe the old carb is savable. Check the return spring on the throttle shaft. It might be weak, missing or placed in the lightest tension hole of its linkage. My new Retrotek FI was doing the same thing as yours. Cory, at the factory, said to put a second return spring on the secondary shaft. That wasn't it. The primary shaft return spring was in the lightest hole. Moved it up one notch, end of problem. And the throttle arm return spring is good. It should be! It's original. And that reminds me, forgot to tell Cory. Gotta call.
128.79mph 1.428 60'
Fred Ficarra is offline
