Holley Accel Pump? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 3rd, 10, 08:20 AM Thread Starter
Gary
Holley Accel Pump?
What are the typical symptoms of a bad, or worn out accel pump? My Holley 670 still has a slight stumble of idle. The carb is about 3 yrs old. Thanks
Gary
Gar's67 is offline
post #2 of 3 (permalink) Old Apr 3rd, 10, 09:21 AM
Re: Holley Accel Pump?
That is a typical symptom. I had the same thing, turned out to be two bad plug wires. Also had it once on a Corvette and it was a cracked porcelain on one spark plug.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is online now
post #3 of 3 (permalink) Old Apr 3rd, 10, 06:10 PM
Alan
If the electronics check out ok from the above suggestion, it could very well be that you need to play with the pump shot. You can get a kit from Holley that has several different cams so you can experiment. Make sure that the pump is adjusted so there is no lag in pump shot coming off the accelerator. In some cases, you might even need to change the nozzle size of the accelerator pump which is also easy to do. Just make sure the butterflies are closed when you change the nozzle. The nozzle is held in via a phillips head screw and watch for the gasket under the screw.
alan
alanrw is offline
