Engine "knock" or "ping"??? - Team Camaro Tech
post #1 of 15 (permalink) Old Apr 6th, 10, 07:38 AM Thread Starter
Joe
My 67 seems to be performing just fine, but I can hear a slight "knock", "click" or "ping" coming from the motor. I have owned this vehicle for 6 months and it's my first classic car. I am not a mechanic at all. What should I do? Please help!!
somocamaro is offline
post #2 of 15 (permalink) Old Apr 6th, 10, 07:47 AM
Skip
Skeeter55's Avatar
Re: engine "knock" or "ping"???
When is it knocking (at start ups/all the time/at idle/or cruising) and what octane of gas are you using.... Could be bad gas or ignition.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 15 (permalink) Old Apr 6th, 10, 07:52 AM
Matt
Could be several things...exhaust leak, worn lifter, worn main/rod bearing or just pinging due to timing/gas, etc. Do you hear it at idle, acceleration, cruse...? Did it just start? What motor and how many miles on it? Do you know what your initial and full advance timing is set at?
Matt
zlek131 is offline
post #4 of 15 (permalink) Old Apr 6th, 10, 07:54 AM Thread Starter
Joe
Thank you for replying. I can hear it at idle and during acceleration. The engine sounds great to me otherwise, but I can just hear the faint "ping" sound. Probably couldn't hear it if you wasn't trying. I have been using the lowest octane or cheapest gas, but I have been driving it 2 or 3 times a week since the weather has warmed up. The oil pressure gauge is within normal ranges. I don't recall hearing the sound during ignition.
post #5 of 15 (permalink) Old Apr 6th, 10, 07:55 AM
Matt
BTW, just noticed "Branson, MO" my old stompin grounds, I grew up in Springfield and ski TableRock every year. Welcome to Team Camaro.
Matt
zlek131 is offline
post #6 of 15 (permalink) Old Apr 6th, 10, 07:56 AM
Skip
Skeeter55's Avatar
Start with some higher octane gas. Also check to see if your vacuum advance is working correctly.
post #7 of 15 (permalink) Old Apr 6th, 10, 07:57 AM
Matt
Sounds like it could be octane/timing issue if you're hearing it during acceleration only. Do know your timing settings?
Matt
zlek131 is offline
post #8 of 15 (permalink) Old Apr 6th, 10, 08:47 AM Thread Starter
Joe
You'll have to forgive me, but you're talking over my head already I have no idea what the timing is set at and wouldn't even know how to check. I love this car and want to learn more, but I'm at ground zero now with my knowledge. I will try a higher octane gas (I know how to find the gas tank). Also, my fiance's dad has a garage and is pretty sharp with this stuff so I can take any suggestions to him and I know he will help.
Matt:
I have been hear my whole life and have enjoyed the lakes too. Originally, I'm from Mansfield, but went to C of O and then law school and came back to the Ozarks. My fiance' is from Denver and we go there for snowboarding every winter.
post #9 of 15 (permalink) Old Apr 6th, 10, 08:51 AM Thread Starter
Joe
I just added some pictures of the my 67
post #10 of 15 (permalink) Old Apr 6th, 10, 09:00 AM
Lex
Lexlas's Avatar
When i first purchased my 68 Camaro it also had a knocking and when i put a new demon carb on it and ran it over 100 miles per hour the engine blew out. Just saying you might not want to run it hard if it's knocking, get it checked first or else you'll have to buy a new engine like me. Lesson learned, i know it's hard to take it easy on a Camaro.
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #11 of 15 (permalink) Old Apr 6th, 10, 10:43 AM
Matt
Yes, try higher octane gas and see if that resolves the issue. If not, I would check the timing next.
I went to Parkview, SMSU (MSU now) moved to KC for 5 years and been in Denver the last decade. Small world...
Matt
zlek131 is offline
post #12 of 15 (permalink) Old Apr 6th, 10, 12:36 PM
Steps
Which tells me that you would not be familar with what a detonation sounds like
Check for any leaks around the exhaust manifilds, in particular the rear ports..check the bolts are tight
Check at night if there are any HT leads jumping/leaking spark
Using a long screwdriver with a solid handle (not rubber) one end on the engine the other to your ear to locate the sound...this will locate stuff like
Check lifters adjusted correctly
A lifter touching the tappet cover (thicker cork gasket fixes)
Alternater, pullys, bellhousing, cracked or collasped piston.
And also put the engine up on a hoist and check the unnder parts of the engine.
Thry the higher octane and also dropping the timing back aboutr 3 degs
Also try disconnecting the VA and block the hose.
Plan of attack:
The 1st think you should do is change the oil, flush radiator and grease
I assume that you are not familar with this
book the car into your local service station, ask that you be there when they do it
Copy this post out and give to them.
While they are doing the service you can watch and learn
They can drop the advance back, use a mechanics stethoscope (instead of the screwdriver) while up on the hoist. and check tappets.
Steptoe is offline
post #13 of 15 (permalink) Old Apr 7th, 10, 06:08 AM
Chuck
Re: Engine "knock" or "ping"???
Not a mechanic at all? Not to be a jerk, but take it to someone who is. You may do far more harm than good if you start messing with it.
Chuck is offline
post #14 of 15 (permalink) Old Apr 7th, 10, 08:26 AM Thread Starter
Joe
Thank you so much for the list. I do have a cousin who has owned about a dozen or so first gen camaros and my father in law is a solid mechanic, so I believe either of them will help me and I will show them this list so they have an idea where to start. Thanks again!
post #15 of 15 (permalink) Old Apr 7th, 10, 01:18 PM
Steps
Go with the 'out-law' a tradesaman mechanic with yrs of experiance and a bit older knowing his way around older technolgy....
There are way too many 'home mechanics' who still believe old wives tales passed down from the neighbours, cousons ex boy freinds big brother who has 'fixed' up lots of old cars
Steptoe is offline
