No Start - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 8th, 10, 06:27 PM Thread Starter
No Start
69 Camaro 427 Probillet Distributor with coil
Where do the red and brown wire go?
The red wire is hot when key is turn on
1969 Camaro Convertible 427 5 Speed
provfirescott is offline
post #2 of 8 (permalink) Old Apr 9th, 10, 02:56 AM
Re: No Start
Into the firewall and never to be seen.
Brown wire may go to the GEN light inside; this side it might go to the alt, #1 spade.
Red wire may go to the fuse panel, IGN spade; this side might have gone to previous HEI distributor.
post #3 of 8 (permalink) Old Apr 9th, 10, 03:08 AM Thread Starter
Re: No Start
So what wires will go and feed my coil to get spark?
post #4 of 8 (permalink) Old Apr 9th, 10, 03:10 AM
Re: No Start
I would try the red wire.
post #5 of 8 (permalink) Old Apr 9th, 10, 11:31 AM Thread Starter
Re: No Start
So the coil only needs a power and a ground going to distributor?
post #6 of 8 (permalink) Old Apr 9th, 10, 06:39 PM
Re: No Start
Yes, ground may be through the dist body.
post #7 of 8 (permalink) Old Apr 10th, 10, 05:28 AM Thread Starter
Re: No Start
So where does the factory tach get hooked into all this.I had a brown wire on the coil is that the tach?
post #8 of 8 (permalink) Old Apr 10th, 10, 05:40 AM
Re: No Start
OE tach wire is green, I think, and gets hooked to neg terminal of coil, dist side of coil..
