98 S10 no start need help - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 24th, 10, 03:27 AM Thread Starter
Dan Ensign
I am helping a friend with a 98 S10 2.2L 5speed that won't start, the injectors pulse for 2 crank revolutions and the plugs fire for two revolutions when cranking and then nothing, crank and cam sensors have been replaced, power goes away from the injectors and the ground signal remains steady, I was told the passkey system may need to be reset, anyone know how to do this. The truck had a stalling issue prior to this but would always restart. Any help would be greatly appreciated.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #2 of 4 (permalink) Old Apr 28th, 10, 06:17 PM
STEVE
Re: 98 S10 no start need help
does this still have a distributor ?
If so, try a different module ( under the rotor )
fast_in_muskoka is offline
post #3 of 4 (permalink) Old Apr 28th, 10, 07:08 PM
Steiner
Have you disconnected the battery for a half hour or so since the replacement? Both of those have to relearn. The information is stored in the ECM so replacement of either sensor or the ECM requires a relearn. For the camshaft sensor the dealer may need to do a procedure but for the cranks sensor I think you can do it. I have a '97 but the '98 and up models are a little different. I replaced my ECM once and didn't have to do anything.
Here is a link to the "CASE" relearn procedure.
http://www.bsecorp.com/files/techtips/ST9303l.pdf
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 4 (permalink) Old Apr 29th, 10, 03:33 AM Thread Starter
Dan Ensign
Thanks for the link, will give it a shot.
Dan E.
Dan E. is offline
