68 Camaro gas tank install issue - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 25th, 10, 07:01 PM Thread Starter
knightmoose's Avatar
Red face 68 Camaro gas tank install issue
68 camaro new installed 16 gallon "REPRODUCTION note OEM?) tank with sending unit rubber ring etc with clams for the hose.
when filling up with gas the gas keeps rushing back up through the neck and spilling onto the ground? Im thinking maybe the neck hose to tank may be on to tight with the hose clamps?
next issue is the fule tank guage works at the instrument clusterwheni turn the car off it goes down 1/4 of as tank when i give it power again it goes back to the normal position? I cant recall if it did this before or if thats normal?
Other tahn those 2 issues everything is secure and works with tha tank installation any advice is greatfully appreciatedthank you.
it about helping others
knightmoose is offline
post #2 of 4 (permalink) Old Apr 25th, 10, 07:52 PM
jim
Re: 68 camaro gas tank install issue
Ive noticed i cant let the gas pump go full throttle when i fill my 67 or it does the same thing!
Laugh a lot, the only other alternative is insanity...
67forever is offline
post #3 of 4 (permalink) Old Apr 26th, 10, 02:50 PM
Brandon
The pump nozzles on todays pumps aren't angled as steeply as they were back when our cars were built. With that said when inserting the zozzle make sure that it's verticle and not slanted to the side. If it's slanted some what, then the restriction is enough to cause the splash out, but soon as the nozzle handle is directly under the piping of the nozzle where the gas passes, the fuel goes straight into the tank.
Brandon J. licence 1NASTY67
Nantooch is offline
post #4 of 4 (permalink) Old Apr 26th, 10, 06:16 PM
Slow fill is normal. May not be normal with the gauge movement as the one coil, empty side, in the gauge may have alittle more magnetism than the other coil, full coil.
