Fuel Gauge Not working - Team Camaro Tech
post #1 of 17 (permalink) Old May 1st, 10, 06:24 AM Thread Starter
Mine goes to
key on: Tan wire disconnected (not grounded) full on gauge
Key on: Tan wire disconnected with jumper to ground full!
Key on: Tan wire disconnected with jumper to ground and also disconnected ground near fuel sender and grounded that to a new ground and still goes to full
1969 Camaro Convertible 427 5 Speed
provfirescott is offline
post #2 of 17 (permalink) Old May 2nd, 10, 08:57 AM
Fred
77thor's Avatar
Re: Fuel Gauge Not working
If it always reads FULL. You may either have an Open circuit (wire is cut/broken) or a bad gauge. Verify the sender first by using an ohmmeter (0 ohms=Empty, 90 ohms=Full).
77thor is online now
post #3 of 17 (permalink) Old May 2nd, 10, 10:33 AM Thread Starter
When key is on and wires are hooked up correctly the gauge reads empty.
post #4 of 17 (permalink) Old May 4th, 10, 06:31 AM Thread Starter
Do this at the connector in the trunk?
post #5 of 17 (permalink) Old May 4th, 10, 07:37 AM
prostreet69camaro's Avatar
Yes you can do it from the connector in the trunk. Just make sure you are on the wire going to the sending unit and not the wire to the guage.
Since you have the wire to the guage grounded and with key on it goes to empty,,then the wiring and guage are good.
What kinda reading do you get on the wire to the sending unit.
There is also a ground wire that connects to the fuel tank strap for the sending unit. You might check that connection and wire.
prostreet69camaro is offline
post #6 of 17 (permalink) Old May 4th, 10, 04:13 PM Thread Starter
Got 12.5 on the ohms.
post #7 of 17 (permalink) Old May 4th, 10, 05:29 PM
Equals around 1/8 tank level.
post #8 of 17 (permalink) Old May 4th, 10, 07:14 PM
Are you getting any voltage at the tan wire in the trunk? Should be 12V there with no current flow. Assuming there is voltage at the guage you have an open circuit between the gauge and the connector in the trunk.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #9 of 17 (permalink) Old May 5th, 10, 08:41 AM Thread Starter
Let you know tomorrow doing a 24 at work today
post #10 of 17 (permalink) Old May 6th, 10, 01:53 PM Thread Starter
Key on
Plug unplugged
Getting 6.53 from tan wire
post #11 of 17 (permalink) Old May 6th, 10, 06:15 PM
Voltage into gauge from electrcal source?
If tan wire is unplugged, as said, 12 volts, or battery voltage minus 0.5 volt, maybe.
If tan wire plugged in, battery voltage to gauge, reduced voltage through gauge.
If you measured 12-13 ohms to ground with tan wire unplugged, then approximately 1/8 tank level.
If you insert a 100 ohm resistor from gauge terminal tan wire was hooked to and ground the other resistor lead, full tank should be indicated - only with tan wire unplugged.
post #12 of 17 (permalink) Old May 8th, 10, 11:17 AM Thread Starter
Dropped gas tank today..............Broken wire on sender!
post #13 of 17 (permalink) Old May 8th, 10, 04:43 PM
Alan
It's always something but at least you found the cause!!!
alan
alanrw is offline
post #14 of 17 (permalink) Old May 8th, 10, 05:48 PM
Roger
rogerh's Avatar
That tan wire is protect pretty good. Can you tell what caused it to break?
Roger
rogerh is offline
post #15 of 17 (permalink) Old May 9th, 10, 06:04 AM Thread Starter
It pulled right out of the rubber boot/connector.Probably happened when I reinstalled tank over winter.
So I sliced the boot in half with razor blade crimped the wire back onto connector and heat shrunk it back together
