Fuel in my vacuum advance can?? - Team Camaro Tech
post #1 of 6 (permalink) Old May 6th, 10, 03:03 PM Thread Starter
Kip
I am getting fuel in my vacuum advance can... Is that normal? If not, what could cause this to happen? I am running a new Speed Demon 650 carb. The vacuum line is hooked up to the full vacuum port on the carb, as recommended by BG, as well as many others.. I have had the distributor out a couple times... and it always has fuel in the can...
I appreciate any thoughts on on the matter..
Thanks,
Kip
kv67ssrs is offline
post #2 of 6 (permalink) Old May 6th, 10, 08:21 PM
Skip
Skeeter55's Avatar
Re: Fuel in my vacuum advance can??
Float levels are to high and make sure the fuel pressure is all good.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 6 (permalink) Old May 9th, 10, 08:32 PM
Fuel can migrate down the vacuum advance line under normal conditions especially if the line runs downhill from the vacuum port to the distributor.
An effective trick is to use a section of metal tubing and bend a loop in it like an upside down "U" so the line runs uphill a few inches before going down to the distributor. The same trick can be used for an auto trans vacuum modulator.
67 Camaro, 96 LT1, 4L60E
red67camaro is offline
post #4 of 6 (permalink) Old Jun 2nd, 10, 03:05 AM
Ed
A while back I had the same issue. I was told to stop overfilling my gas tank (read not to "top it off"). When the nozzle clicks off near the full mark, call it "good". Problem cleared right up. try it.
Ed
edpdx is offline
post #5 of 6 (permalink) Old Jun 9th, 10, 09:33 AM
Fred
So that's why my stock modulator pipe has an upward curve behind the TB. And I thought it was to access the dizzy bolt.
128.79mph 1.428 60'
Fred Ficarra is offline
post #6 of 6 (permalink) Old Jun 9th, 10, 02:09 PM
Steps
Damn I have for yrs looked abstractly at the VA and always thought lazy buggers not making them straight....
never had a problem of fuel in the VA, use manifold vac off the valley cover....and running LPG suppose it wouldnt matter lol
Steptoe is offline
