1970 Camaro passenger door lock broken - Team Camaro Tech
post #1 of 5 (permalink) Old May 18th, 10, 06:49 PM Thread Starter
Today I tried to unlock the passenger door on my 1970 Camaro (custom interior) and the lock is stuck/not functioning. The door is closed. How do I fix this if the door is closed?
jtwoods4 is offline
post #2 of 5 (permalink) Old May 19th, 10, 04:11 AM
BILL
SPARKY69's Avatar
Re: 1970 Camaro passenger door lock broken
your going to have pull the door panel away a bit or off if you can to get your hand in there to unlatch the door to pop it open..it can be done!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #3 of 5 (permalink) Old May 19th, 10, 10:02 AM Thread Starter
Today I rolled down the window and shined a flashlight down inside the door. The rods and door handles are all connected and working. The problem is when the handle is pulled the release lever does not engage the latch and release it, hence the door will not open. I have sprayed WD40 into the components and even tried the old slim jim trick. No luck. Anymore ideas? The door is closed so not sure how I can take apart to fix.
jtwoods4 is offline
post #4 of 5 (permalink) Old May 21st, 10, 10:15 AM
Eric
Move your door handle while looking at the latch.The lever that is moved by your door handle pushes another lever that is stuck in the opening position.You must trip THAT lever back to the closed position with a long screwdriver or rod and then unlock the door and then the door will open.
69 SS396 fathom green N/A525 833chrysler 4spd 3550# stock suspension 10.11/137mph
vonzipper396 is offline
post #5 of 5 (permalink) Old May 21st, 10, 12:34 PM Thread Starter
The WD40 trick worked. After about an hour of jiggling and pulling the latch came off the striker pin and the door opended. It looks like the latch was painted by the last owner and that caused it to stick in the locked position. It finally opened. Thanks for the help guys, I was about to start taking the door panel off with a closed door and probably ruin it.
jtwoods4 is offline
