Holley Carb Leaking on 67' Camaro BB PLEASE HELP - Team Camaro Tech
post #1 of 7 (permalink) Old May 26th, 10, 06:36 PM Thread Starter
Justin
Hey guys our 67' camaro with a 454/4bbl holley randomly started leaking out of a bizarre area. See the picture, where it's circled; this is where it is leaking after about 30 seconds of run time.
It seems to be around the 5 brass plugs in the carb? I quickly took it apart and the gaskets seem OK
Once it starts leaking out it eventually kills the motor. What could this be?
Thanks guys!
1967 RS/SS--BB-4spd.
Justin
Fuzzyhall is offline
post #2 of 7 (permalink) Old May 26th, 10, 07:41 PM
Randy
Re: Holley Carb Leaking on 67' Camaro BB PLEASE HELP
looks like a metering block gasket or one of the brass plugs is leaking
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #3 of 7 (permalink) Old May 26th, 10, 08:22 PM
ZZ_430's Avatar
Restake the plugs and use JB weld or replace metering block.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 7 (permalink) Old May 27th, 10, 04:47 PM
cb
Send a message via Yahoo to flyingskibiker
Are you sure its not coming out of the vent tube? Is your float level set correctly? Just checkin'... ;-)
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #5 of 7 (permalink) Old May 27th, 10, 05:15 PM
Check to make sure the blocks are not warped i had this happen to me before, if you overtighten the fuel bowl screws it can happen
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #6 of 7 (permalink) Old May 28th, 10, 12:17 PM Thread Starter
Justin
Could it be the float sticking?
Thanks for the help guys. We are going to fool around with it later tonight. Are the brass plugs pressure fit? How do you know how
hard" to knock them in?
Thanks again
Justin
post #7 of 7 (permalink) Old May 31st, 10, 11:06 AM
morris
I would change the gasket also
hydromo is offline
