Two issues - Team Camaro Tech
post #1 of 25 (permalink) Old Jun 6th, 10, 03:31 PM Thread Starter
Keith
Two issues
OK--I have two issues that I discovered right about the same time--wondering if they have anything to do with each other.
1. The motor will have slight run-on (only sometimes). At these times, a typical start up immediately after will require the accelerator to be pushed all the way to the floor (as if the carb was flooded). I suppose here, the carb floats could need to be adjusted (not done since the I rebuilt it last year), but I have not had any issues prior to a couple of weeks ago.
2. I installed a new voltage regulator (the solid state kind) a couple of months ago--perfect at 14 volts--I noted that now, the volt meter reads only about 11 volts when the engine is running.
Could these items be related to a bad alternator somehow?
Quick info:
Motor is a 383 stroker, very lumpy idle (max vacuum at idle is about 5 inches), with a Holley 650 DP, and HEI ignition, running about 12-14 BTDC at idle, vaccume removed.
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 25 (permalink) Old Jun 6th, 10, 06:29 PM
DjD
DjD's Avatar
Re: Two issues
Run-on can be caued by the throttle blades being too far open at idle... A typical fix is to add initial timing (will raise the idle more) then close the throttle blades to bring the idle back down...
...Dennis
DjD is offline
post #3 of 25 (permalink) Old Jun 6th, 10, 07:40 PM
george
Re: Two issues
Yep..low systems volts will affect all electrical ckts including the 12 volt hei distributor.
You need a fully charged battery before diving into the charging system.
I would start there before replacing parts or twisting on the dizzy.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #4 of 25 (permalink) Old Jun 7th, 10, 04:25 AM Thread Starter
Keith
Re: Two issues
Charged the battery yesterday afternoon to full charge (float charger) went to standy...
Started the car, still shows 11 volts on the voltmeter...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #5 of 25 (permalink) Old Jun 7th, 10, 04:44 AM
Re: Two issues
When it shows 11 volts on the voltmeter, what do you read across the battery posts?
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #6 of 25 (permalink) Old Jun 7th, 10, 02:56 PM Thread Starter
Keith
Re: Two issues
Have not yet checked that...will do so and post the results...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #7 of 25 (permalink) Old Jun 7th, 10, 04:30 PM Thread Starter
Keith
Re: Two issues
Volts across the battery with engine running show 11.76
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #8 of 25 (permalink) Old Jun 7th, 10, 07:13 PM
morris
Re: Two issues
sounds like a bad alternater
hydromo is offline
post #9 of 25 (permalink) Old Jun 8th, 10, 03:25 AM
Re: Two issues
X2
If the alternator/regulator is working properly, you should see 13.5-14.5volts there.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #10 of 25 (permalink) Old Jun 8th, 10, 07:37 PM Thread Starter
Keith
Re: Two issues
I got an old alternator on the shelf--worked when I took it off the car 8 years ago to put the chrome alternator on...I'll install it htis weekend and see if my results are different...
Thanks for the insight.
So, do you think a bad alternator could cause a gremlin in the distributor to create my slight run-on issue?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #11 of 25 (permalink) Old Jun 9th, 10, 09:29 AM
Fred
Re: Two issues
Don't see how,,,, and send that alternator over here with $5. I'll fix it.
128.79mph 1.428 60'
Fred Ficarra is offline
post #12 of 25 (permalink) Old Jun 9th, 10, 04:58 PM Thread Starter
Keith
Re: Two issues
Seriously?? PM m me with your address, if so...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #13 of 25 (permalink) Old Jun 9th, 10, 10:18 PM
Fred
Re: Two issues
Keith! After I wrote that, the old diode run-on affliction prevention came to mind. Just surfed to add it but you must be thinking the same.
128.79mph 1.428 60'
post #14 of 25 (permalink) Old Jun 10th, 10, 10:52 AM Thread Starter
Keith
Re: Two issues
The seroiously part was the $5 buck fix, not relating to the not affecting run-on...sorry if it seemed I was being a jerk--did not intend that at all--what is the diode run-on affliction prevention?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #15 of 25 (permalink) Old Jun 11th, 10, 10:55 AM
Fred
Re: Two issues
No offense taken Keith. The run-on problem is when changing alternators as I recall. They sometimes back bleed juice to the distributor and cause the engine to keep running when the key is turned off. The fix is a diode in the output wire of the alternator. If I got that wrong, it'll take about two seconds for a correction to post. Stay tuned.
128.79mph 1.428 60'
