Camaro spits back through the carb - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 1st, 10, 11:23 AM Thread Starter
Florida69Camaro
I have an 81 Camaro, it has a 350 with a Holley 750 dp, the car came from 4700' elevation and now is at 5' elevation, it idles fine but when you rev it up it will s\pit and backfire through the carb, if you ease into the gas it's fine, it doesn't matter if you sitting still with no load or if your going down the road........
florida69camaro is offline
post #2 of 8 (permalink) Old Jul 1st, 10, 12:38 PM
Derek
Dereka's Avatar
Re: Camaro spits back through the carb
i would say it is way lean
Dereka is offline
post #3 of 8 (permalink) Old Jul 1st, 10, 01:08 PM
Steps
lean pops thru the exhaust...the only way to pop back thru the carb is HT lead around the wrong way, valve not seating..that latter could be seveal reasons.
the cyclinder is closed off from the inlet...and the only way it can pop back is if that 'sealing' is not there.
Steptoe is offline
post #4 of 8 (permalink) Old Jul 1st, 10, 01:24 PM
BILL
SPARKY69's Avatar
needle and seat stuck?
timing off?
wire crossed?
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 8 (permalink) Old Jul 1st, 10, 02:05 PM
timing off?
wire crossed?
X2 dirt in the needle and seat making it stick
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #6 of 8 (permalink) Old Jul 1st, 10, 03:59 PM
Dan Ensign
I agree with DEREKA, definitely too lean, lean pops back thru carb. rich pops in exhaust.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #7 of 8 (permalink) Old Jul 1st, 10, 04:28 PM
Harry
dawg's Avatar
clogging cat!
434 stroker
US Navy retired
dawg is offline
post #8 of 8 (permalink) Old Jul 3rd, 10, 07:02 PM
Keith
solid or hydraulic cam...
I had a similar problem on my solid lifter cam engine--valves wer eout of adjustment...adjusted the valves--no more issues!
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is online now
