Help car stops running - Team Camaro Tech
post #1 of 14 (permalink) Old Jul 10th, 10, 02:02 PM Thread Starter
I was driving down the road in the 69 z/28 302 - doing about 65 mph when the engine just stopped running.
Engine is stock 302, got it home and installed a GM replacement distributor/cap, rotor and points set. Because of no spark out of distributor.
Car ran great for about 50 miles then. STOPPED RUNNING, got it off the road and got it started again.
ANY IDEAS AS TO THE PROBLEM HERE. AND THE FIX????
Worried about this happening again.
tazmanfire is offline
post #2 of 14 (permalink) Old Jul 10th, 10, 05:17 PM
Re: Help car stops running
Coil overheating? Most of the time, warmer than warm, overheated coil is HOT!
Take along an extra and swapout when it happens
Everett#2390 is online now
post #3 of 14 (permalink) Old Jul 11th, 10, 06:16 AM Thread Starter
Thought of the coil overheating but with only a 3 minute cool down, car started and drove home in 20 minutes with no more problems. However, I will have an extra coil with me just in case.
post #4 of 14 (permalink) Old Jul 11th, 10, 09:02 AM
You might rig up as an indicator inside a test light, could be a 194 or a 63 bulb & socket, and attach it to the coil + terminal to see if ign voltage disappears.
post #5 of 14 (permalink) Old Jul 12th, 10, 08:26 AM Thread Starter
I will take my 12 volt light tester with me when I go out for drive. See what it does.
I think light goes OUT with key on problem is in ignition side of coil. If light is still ON
problem is on distributor side. RIGHT
post #6 of 14 (permalink) Old Jul 12th, 10, 12:54 PM
Correct. I was thinking of a light monitoring all the time, but you should see a change somehow.
post #7 of 14 (permalink) Old Jul 12th, 10, 01:38 PM
Lex
Lexlas's Avatar
One time thata was happening to me and it was because the distributor was wet, water had somehow gotten inside. Moisture was preventing it from turning back on. Just my guess.
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #8 of 14 (permalink) Old Jul 12th, 10, 02:52 PM
I had one of those quick disconnect things on the battery go south on me and did the same thing. The one where you turn the knob to stop the draw. Got rid of it and no more problems.
Johns 67 is offline
post #9 of 14 (permalink) Old Jul 12th, 10, 05:23 PM Thread Starter
No way water was involved here this time. But I have had that happen on another classic.
No kill switch here either. But I understand the idea. That is why I am working the test light process, it may prove helpful. I agree the light should be of the constant kind inside the car. That way when power fails I will see light DIE right then.
post #10 of 14 (permalink) Old Jul 12th, 10, 06:04 PM
Correct, it can be a plastic rear light socket with long leads and alligator clips to attach.
post #11 of 14 (permalink) Old Jul 15th, 10, 07:42 AM Thread Starter
Decided running wiring/light was a pain and just changed to a new coil unit. Will carry spare for awhile just in case, it happens again.
Thanks to all,
post #12 of 14 (permalink) Old Aug 7th, 10, 08:48 AM Thread Starter
Hi again, Thought problem was gone. Shut down again last night on highway.
Got it towed home.
LAST NIGHT checked for power at coil. RESULTS
Key OFF ----NO POWER ON EITHER SIDE OF COIL.
Key ON ----- NO POWER ON EITHER SIDE OF COIL.
TEST THIS MORNING RESULTS
KEY OFF ---- NO PWER EITHER SIDE OF COIL
KEY ON ----- POWER ON BOTH SIDES OF COIL
ANY IDEAS I WILL PAY PHONE BILL TO CALL YOU.
post #13 of 14 (permalink) Old Aug 7th, 10, 09:36 AM
James
Maybe ignition switch is bad. Try wiggling key in the switch when you have no power when key is on. happend to me once, same scenario. Good luck! check back of ignition switch connections, maybe loose harness.
James
Espanola, New Mexico
67 RS/SS click my profile to see pic
james_m_ag is offline
post #14 of 14 (permalink) Old Aug 7th, 10, 01:17 PM Thread Starter
To all out there. I got into the ignition wiring and found the problem (or wiring that was not suppose to be there for old style dist. systems.
Removed ballast resistor (electronic dist. type) and wires for there thing.
Replaced 1 of the + side wires on coil that was bent over on itself (hard and getting HOT).
Back together and went for semi hard drive and no problems. WE WILL SEE.
Thanks for all the help
