smoke when shifting - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 12th, 10, 08:44 PM Thread Starter
steve
smoke when shifting
Hello I have a 68 rs with a 327 with around 2000 miles on it.It seems to be blowing a puff of smoke when shifting gears at a higher rpm.When I'm in my drive way in neutral it doesn't seem to do this.I can sometimes hear ticking from the drivers side valve cover at an idle.Anyone have sugestion on what could cause this.
INPLUMSDEEP is offline
post #2 of 11 (permalink) Old Jul 13th, 10, 07:20 AM
foreverlookin's Avatar
Re: smoke when shifting
Do you have headers? The ticking sound could be an exhaust leak. The motor only has 2k on it give it some more miles before getting concerned on huffing a little oil, as long as it is only a little.
foreverlookin is offline
post #3 of 11 (permalink) Old Jul 13th, 10, 07:29 AM
Russ
Ticking at the valve cover sounds like a tight or loose valve. Check your valve lash and re-adjust if not within spec for your cam.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #4 of 11 (permalink) Old Jul 13th, 10, 08:08 AM
Marty
It could also be a bad valve guide/s.
martZ is offline
post #5 of 11 (permalink) Old Jul 13th, 10, 08:50 AM
I agree with just adjusting the valves.
deerhunter is offline
post #6 of 11 (permalink) Old Jul 13th, 10, 09:45 AM Thread Starter
steve
Thanks for the quick response i will adjust my valves tonight also do you think it could be from too much fuel it only happens when the carb is wide open.
post #7 of 11 (permalink) Old Jul 13th, 10, 05:17 PM
If it was fuel related I would think it would stumble along with the smoke.
Auto or stick?
400bird is offline
post #8 of 11 (permalink) Old Jul 13th, 10, 10:14 PM Thread Starter
steve
stick
post #9 of 11 (permalink) Old Jul 14th, 10, 05:11 PM
It may be fuel related, you have to let off the gas and stomp it back down, the accelerator pump may be pushing more fuel than needed.
I would think that would cause a stumble, however.
What carb does it have?
400bird is offline
post #10 of 11 (permalink) Old Jul 15th, 10, 12:18 PM Thread Starter
steve
holley 650
post #11 of 11 (permalink) Old Jul 15th, 10, 05:33 PM
If its a double pumper try disconnecting the rear accelerator pump and drive again. Its probably going to stumble (lean) every time you open the secondaries, but watch for the smoke
That said I have no idea how to easily disconnect accelerator pumps.
400bird is offline
