engine wants to stall when I put into drive - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 22nd, 10, 06:49 PM Thread Starter
Hi, I have a 1969 Camaro 350, 350 trans. When I put the trans into drive it want to stall. When I;m driving its hard to keep it from stalling at lower speeds. Any ideas. Thanks
sprint1004 is offline
post #2 of 6 (permalink) Old Jul 22nd, 10, 06:59 PM
Skip
Skeeter55's Avatar
Re: engine wants to stall when I put into drive
Vacuum line to the trans/carb disconnected or cracks in the line.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 6 (permalink) Old Jul 22nd, 10, 07:14 PM Thread Starter
I cant find a hose comming from the trans what side will it be on
post #4 of 6 (permalink) Old Jul 22nd, 10, 07:19 PM Thread Starter
Now my brake peddle is going down to the floor could all this be related to a vacumm problem
post #5 of 6 (permalink) Old Jul 22nd, 10, 07:32 PM
Skip
Skeeter55's Avatar
Yes check the vacuum hoses from the brake booster to the carb and the tee and to the vacuum module on the trans.
post #6 of 6 (permalink) Old Jul 23rd, 10, 09:41 AM
Cruzin "the 82"
angelglo's Avatar
you can check vacuum leak by gettin gcar cleaner and spraying at the hoses. if idle goes up, you've found the leak
angel
angelglo is offline
