tight steering - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 4th, 10, 06:18 PM Thread Starter
tight steering
Just replaced the power steering gearbox on my '67 due to it leaking. Replaced with a remanufactured one that was a direct bolt on. At the same time I removed my steering column, and took it to be rebuilt, where they replaced steering coupler, upper/lower bearing and turn plate spring. I reinstalled column, and flushed pwer steering system and checked for leaks.... All looked well and the steering is deff more responsive but is tight as hell, no return to center, even small adjustments like lane changes require me to actually turn wheel back once I change lanes, if that makes sense.... No matter where I turn steering wheel, it will stay right there if I dont turn it back..... Do you guys have any ideas what might be the problem? Thanks for the help, and sorry this is so long, I just wanted to describe it as accurately as possible
gatortalk is offline
post #2 of 6 (permalink) Old Aug 4th, 10, 06:52 PM
Steiner
Re: tight steering
Car off, wheels off the ground, how does it feel?
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 6 (permalink) Old Aug 4th, 10, 10:54 PM
Re: tight steering
don't know what the problem is with your car.i have a 67 that was leaking around the Pittman arm.it was never tight could turn wheel with 1 finger,i put new seal kit in around the Pittman arm & the seal in where the rubber coupler is & mine is like yours.I'm thinking when i tightened up the big nut where the seal is at the rubber coupler i over tighten it.i don't know if that's my problem,but i did use a lot of muscle on the nut i was afraid it would leak.might be your problem to.I'm just guessing.i haven't had time to try & loosen it up yet
anthony hisle is offline
post #4 of 6 (permalink) Old Aug 5th, 10, 02:05 PM Thread Starter
Re: tight steering
exactly the same
post #5 of 6 (permalink) Old Aug 5th, 10, 06:52 PM
Steiner
Re: tight steering
Try removing the two bolts from the steering coupler and rag joint. See how just the steering wheel and shaft feel when uncoupled from the box.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 6 (permalink) Old Aug 6th, 10, 03:56 AM
Steps
Re: tight steering
Yeah...I did the same yrs back..no interent lol
basically loosen all the mounting pionts...then do up.
From memory it is the floor covers that need doing last??
Steptoe is offline
