Fuel guage - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 7th, 10, 05:38 PM Thread Starter
Fuel guage
Had a problem with my guage reading way past the full mark when tank was full,so i replaced the sending unit now its fine reads right at the full mark when tank is filled,but now i run out of fuel when guage reads right around the 1/4 mark what would cause this?Any help appreciated.
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #2 of 10 (permalink) Old Aug 8th, 10, 12:39 PM
Bruno
Re: Fuel guage
Bent fuel pick up tube? Wrong ohms range sender?
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #3 of 10 (permalink) Old Aug 8th, 10, 03:41 PM
Fred
77thor's Avatar
Re: Fuel guage
Originally Posted by ORENCH View Post
Bent fuel pick up tube? ...
I agree. Make sure that the pickup tube is at/near the bottom of the tank.
77thor is offline
post #4 of 10 (permalink) Old Aug 8th, 10, 04:17 PM Thread Starter
Re: Fuel guage
Guess this means i have too drop the tank again was hoping it was something easier.
Bad67355 is offline
post #5 of 10 (permalink) Old Aug 8th, 10, 05:19 PM Thread Starter
Re: Fuel guage
I checked ohms on the brown wire in the trunk with it disconnected from the plug and key off was 40.7 ohms gas guage reads in between 1/2 and 1/4 does this sound about right?
Bad67355 is offline
post #6 of 10 (permalink) Old Aug 8th, 10, 05:51 PM
Bruno
Re: Fuel guage
Sender value goes from 0 to 90 ohms, thus 45 at 1/2.
ORENCH is offline
post #7 of 10 (permalink) Old Aug 8th, 10, 05:52 PM
Larry
larryh56's Avatar
Re: Fuel guage
This is the best process I have seen to check everything out. Very straight forward and simple.
http://www.chevelles.com/techref/ftecref18.html
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #8 of 10 (permalink) Old Aug 8th, 10, 08:59 PM
Re: Fuel guage
When you "run out" and the gauge still shows 1/4 tank, how much gas does it take to fill it back up? That will tell you a lot. The tanks hold 18 gal when empty, but you can probably only use 17ish gallons of that.
BPOS is offline
post #9 of 10 (permalink) Old Aug 9th, 10, 02:10 PM Thread Starter
Re: Fuel guage
I will check this next time i fill up although i dont like to use much pump gas this is something i will definitly check thanks.
Bad67355 is offline
post #10 of 10 (permalink) Old Aug 14th, 10, 01:48 PM Thread Starter
Re: Fuel guage
So whats does everybody suggest try and bend the pickup tube a little so its further down near the bottom?If so how much should i bend it ?any other thoughts?
Bad67355 is offline
