why is my 88 iroc-z not firing? - Team Camaro Tech
post #1 of 23 (permalink) Old Aug 18th, 10, 09:08 AM Thread Starter
marcus
i have new coil and everything put still no fire someone please help.
jemarcusray is offline
post #2 of 23 (permalink) Old Aug 18th, 10, 09:06 PM
Re: why is my 88 iroc-z not firing?
Why send me a private message? Did you just send PM's out to random members?
I don't know much about an 88
Any power to the coil?
You say coil and everything, whats everything?
400bird is offline
post #3 of 23 (permalink) Old Aug 18th, 10, 11:56 PM
Harley
wiskeesour's Avatar
1.) When you turn the motor over, does a nice colorful spark happen when you ground the plug against the block? If so, what color is the spark?
2.) What have you touched OR replaced between when the motor was running and now?
3.) Are you sure the motor is getting fuel?
4.) 88 IROC, is it a TPI 305 or the TPI 350 or is it carb or Throttle Body? Standard or Auto?
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #4 of 23 (permalink) Old Aug 19th, 10, 06:54 AM Thread Starter
marcus
distributor and the cap twice and the coil three times but still nothing its getting fire to the coil but not pushing out and its grounded
post #5 of 23 (permalink) Old Aug 19th, 10, 07:09 AM
Harley
wiskeesour's Avatar
try the ignition control module under the cap...?
Thanks Chief.
post #6 of 23 (permalink) Old Aug 19th, 10, 09:36 AM Thread Starter
marcus
that brand new too the second one
post #7 of 23 (permalink) Old Aug 19th, 10, 10:20 AM
Harley
wiskeesour's Avatar
have you tried troubleshooting with a known good distributor?
Thanks Chief.
post #8 of 23 (permalink) Old Aug 19th, 10, 10:43 AM
With the distributor cap off, does the rotor spin when cranking the engine over?
Is there battery power to the distributor?
Are the spark plugs wet with fuel?
Everett#2390 is online now
post #9 of 23 (permalink) Old Aug 19th, 10, 01:11 PM Thread Starter
marcus
yes the rotor spin, yes there is power to the distributor, yes the plugs are wet
post #10 of 23 (permalink) Old Aug 19th, 10, 01:13 PM Thread Starter
marcus
and its not firing with no distributor
post #11 of 23 (permalink) Old Aug 19th, 10, 01:24 PM
With no dist. I can promise you it will not fire or start.
john68 is offline
post #12 of 23 (permalink) Old Aug 19th, 10, 04:39 PM Thread Starter
marcus
not with no dist, with any dist i put in it, sorry bout thaT
post #13 of 23 (permalink) Old Aug 19th, 10, 05:28 PM
In changing the coil, is the ground lead screwed underneath one of the coil mounting screws?
Is the spring-loaded button in place between the coil and rotor?
Plugs being wet is good, meaning the the dist is sending reference pulses to ECM and injectors are opening - pulsing.
With timing light on #1 cylinder plug wire, is there a light? And does the flash show the timing marks? At the right time? 10 to 16 BTDC? With EST not bypassed, ECM is controlling aprk timing - disconnect the brown/black wire on pass firewall to bypass and spark will be distributor controlled.
post #14 of 23 (permalink) Old Aug 20th, 10, 05:32 PM Thread Starter
marcus
my coil is not on my dist it sit by its self, i cant do all of that if its not fring
post #15 of 23 (permalink) Old Aug 20th, 10, 08:37 PM
You never answered my question.
How are you testing for spark?
400bird is offline
