Backfire Thru Carb From Running Great?? - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 18th, 10, 11:29 PM Thread Starter
HELP!! My 327 with MSD ignition was running great. Timing was right on. Today, leaving work, went a block and it started poping through the carb. Engine starts but wont idle or run without gas peddle and it just backfires through the carb.
I just had the MSD Ready To Run Pro Billit rebuilt by MSD with new gear, cap, rotor and PC Board, installed it a week ago with new coil. I checked NO 1 TDS and rotor alignment and it was good. Distributor hadn't moved. Anyone have a clue how to diagnose this? I will be eternally grateful!
Many thanks,
smiller is offline
post #2 of 8 (permalink) Old Aug 31st, 10, 12:39 PM
Wes
Re: Backfire Thru Carb From Running Great??
Possible solutions:
1) Firing order problem
2) Bad plug wires
3) Cracked distributor cap
4) Broken valve spring(s)
Straight-line-69 is offline
post #3 of 8 (permalink) Old Aug 31st, 10, 12:51 PM
Steps
Change the spark plugs
Steptoe is offline
post #4 of 8 (permalink) Old Sep 1st, 10, 06:54 PM
5. bent or broken push rod
6. wiped cam
EricE
68 Butternut Yellow
SS Coupe 396/325
stope4 is offline
post #5 of 8 (permalink) Old Sep 2nd, 10, 06:10 AM
Chuck
If not igniton related, can also be caused by a lean condition. Accelerator pump not working, loss of fuel pressure to carb, float sticking.
Chuck is offline
post #6 of 8 (permalink) Old Sep 2nd, 10, 10:55 AM
You may want to pull the distributor to make sure there's no problem with the gear that engages the cam. It may have some bad teeth that changed the timing on you, although this would show up with a timing light. I always look at the last thing changed when troublshooting a new problem.
reelknots is offline
post #7 of 8 (permalink) Old Sep 2nd, 10, 01:41 PM
Steps
The question was raise a fortnight ago, the guy hasnt been back since asking.
Steptoe is offline
post #8 of 8 (permalink) Old Sep 2nd, 10, 08:18 PM
Maybe he's still driving home!!!
