My pass side low beam keeps blowing... - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 19th, 10, 12:26 AM Thread Starter
Harley
wiskeesour's Avatar
Ive looked and searched and can not figure out why my low beam on the passenger side keeps blowing. It takes about 2 weeks after a new bulb and quits working. The high beam on the pass side still works but the low beam quits.
What could be causing this? Anyone have a guess?
As always help is greatly appreciated...
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #2 of 8 (permalink) Old Aug 19th, 10, 02:30 AM
Steiner
Re: My pass side low beam keeps blowing...
I would guess poor connection in the terminal socket. You may be able to see signs of overheating on the connector and maybe you can push the terminals out to see if they need to be redone with solder.
On a side note, a great upgrade is a relay harness. You can get them for about thirty bucks on ebay although with the cheap ones the terminals are just crimped and need to be soldered. It's a pigtail that connects to the battery and then your original connectors plug in on one side and the other side plugs into your headlights. It'll put full battery voltage on the headlights instead of having to run through your headlight switch.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 8 (permalink) Old Aug 19th, 10, 07:15 AM Thread Starter
Harley
wiskeesour's Avatar
I searched for 68 camaro headlight relay harness to no avail.
Got a link? Appreciate the help Steiner...
Thanks Chief.
post #4 of 8 (permalink) Old Aug 19th, 10, 12:02 PM
one other thing to look at is your voltage regulator output. mine was fine at idle but 16v at 3k and blew 3 drivers side headlights nbefore i figured it out.
Dave69Z is online now
post #5 of 8 (permalink) Old Aug 19th, 10, 12:18 PM
Michael
Or the headlight bucket isn't anchored with enough bolts and the vibration from driving is shaking the filament loose.
mahunt is offline
post #6 of 8 (permalink) Old Aug 19th, 10, 06:00 PM
Steiner
This is the one I have. I got it so I could run high wattage lamps. It's not installed yet though.
http://cgi.ebay.com/ebaymotors/H4-90...ts_Accessories
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 8 (permalink) Old Aug 19th, 10, 10:34 PM
Steps
As above it is a symptom of poor connections in partular bad grounds causing higher restance and too much current going thru the filiment
You would most prob also blow the hi beam if used that as much.
Check the ground from the bulb to body with a ohm meter....thats thru the spade connector, the ground poor connection could be in there and/or to the body.
Steptoe is offline
post #8 of 8 (permalink) Old Aug 20th, 10, 12:30 AM Thread Starter
Harley
wiskeesour's Avatar
OKEY DOKEY....Thanks Steps, Guys... Ill post what happens...
Thanks Chief.
