Knocking noise during acceleration and deceleration - Team Camaro Tech
post #1 of 19 (permalink) Old Sep 3rd, 10, 08:54 AM Thread Starter
Giorgio
I need some help . my 1968 Camaro automatic with TH400 and 10 bolt rear end makes a hard knocking noise during acceleration and deceleration.
The noise gets harder when car is driven more than half an hour.
Also during shifting without car movement you can hear the noise .
This are the parts I have already changed :
The automatic transmission was rebuild 450 miles ago
Drive shaft front and rear joints are changed.
10 bolt rear end Spider gears are changed and the differential play was adjusted.
And at least ( yesterday) the transmission flange of the TH400 was changed because it has some play.
But the knocking noise is still there first quiet and gets louder as the car is driven longer .
I don't know what else to change or to look for , has anybody some ideas or had the same problem?
The guy who overhauled the automatic is comming on Monday to have a look , but he told me on the phone that the TH400 is in perfect shape after the overhaul and that is not the cause of the noise.
Trickerlog is offline
post #2 of 19 (permalink) Old Sep 3rd, 10, 03:00 PM
Steps
Re: Knocking noise during acceleration and deceleration
Suerly you can tell if in the rear or trans????
I would suspect wrong oil in the diff or aditives not added.
Steptoe is offline
post #3 of 19 (permalink) Old Sep 3rd, 10, 03:20 PM
Ron
Rod Bearing, if it gets louder under engine braking.
This was my 70 1/2 Z28
Z15CAM is offline
post #4 of 19 (permalink) Old Sep 4th, 10, 02:57 AM Thread Starter
Giorgio
The diff oil was changed after spider gear change and it was filled up with the right one.
Engine braking noise?During engine braking there is no noise!
The Noise is only a short knock when pushing the gas pedal or lift off the gas pedal.
I can not really locate the knocking , first I thought it came from the joints of the drive shaft, but they are now both changed.
post #5 of 19 (permalink) Old Sep 4th, 10, 11:46 AM
jimbo68's Avatar
Don't forget to check that a converter to flywheel bolt did not come loose and back out a few threads. They first rub some making a clunking noise the turn to a nasty knocking as they chew the starter noise! I actually found aluminum shavings under my car in the garage due to this!
jimbo68 is offline
post #6 of 19 (permalink) Old Sep 4th, 10, 01:16 PM
Steps
That knock you cant find? but its up front right?
Really hate when it cant be found...to often its a collasped or cracked piston.
With the car up on a hoist is it loader? from the engine?
Get a mechanics stethosope..they are cheap and a must for the tool box, then listen around and isolate
Cracked and collaped piston are notorious to sort of harmonic around in the engine making impossible to locate without a stethoscope.
Locate the sound, till then everything is just a huge list of speculation.
Hell it could just end up being detonation
Steptoe is offline
post #7 of 19 (permalink) Old Sep 4th, 10, 01:32 PM
Jeremiah
Check the cearance between the starter gear and flywheel also. Mine was making an odd noise and sounded like it was comming from the lower end and thats what it turned out to be.
I ended up having to clearance the starter gear slightly to gain enough clearance. The flex plate lived up to it name flexing just enough under accelleration to make contact.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #8 of 19 (permalink) Old Sep 5th, 10, 03:17 PM
Ron
An Exhaust Header Gasket can sound like a TIC similar to a Valve Train issue but you say a "Knock" and it does not do it under Engine Braking. That's a Good Sign which indicates the Bearings are probably OK. I would Check for Cracked Flex Plate - Fuel Pump Push Rod issue, which can include the Pump Eccentric Lobe worn on cam. If All Check OK then do a Leak Down Test which can identify Piston Skirt Damage. Another possibly is Wrist Pin. Also check Crankshaft end play for Thrust Bearing Wear.
Check for Metal in the Oil.
Z15CAM is offline
post #9 of 19 (permalink) Old Sep 8th, 10, 04:50 PM
First thing I'd check are the torque convertor bolts - especially since you just had the tranny rebuilt. I'd bet they're loose.
69 RS, Hugger orange/black, Deluxe interior, Sony AM/FM/XM/CD, PS & PB. 355, forged pistons, Eagle rods, balanced, Iron Eagles, 9.4:1 CR, .038 quench, XR270HR Cam, Z28 intake, FAST-EZ EFI 2.0, Thorley Tri-Ys, TCI 700R4, 2400 stall, 3.42 posi
LukeWarm is offline
post #10 of 19 (permalink) Old Sep 9th, 10, 08:41 AM
Matt
Does it sound anything like this: Listen for the faint "clunk"...
http://www.mattlekawa.com/pictures/c...trnasClunk.wmv
Matt
zlek131 is offline
post #11 of 19 (permalink) Old Sep 9th, 10, 02:03 PM
Steps
He hasnt been back for update in the last 5 days...
Steptoe is offline
post #12 of 19 (permalink) Old Sep 9th, 10, 10:56 PM Thread Starter
Giorgio
The automatic gear is removed and I wait for the answer of the gear overhaul guy.
So if I got any more informations I will post them and I can't check anything because the automatic gear is removed.
Thanks for all your help .
post #13 of 19 (permalink) Old Sep 11th, 10, 02:58 AM Thread Starter
Giorgio
I've taken a film of the knocking noise, it is taken from the rear because you can hear it better without the engine noise.
Engine is running the gear handle is changing from N to R and D.
Here the noise :http://img689.imageshack.us/img689/3610/mov07305.mp4
post #14 of 19 (permalink) Old Sep 11th, 10, 10:02 AM
Jeremy
DUDE! Your driveshaft shifts in the video! thats with the car in park?! make sure ur driveshaft is secure! that looked almost like a death sentence man! filming that car underneith while its running, the thing looks like the torque converter might engage. u better chec ur spindle the shaft slides onto. also that torque converter may be shot! good luck man
]- Its legal unless you get caught. -[
jeremycam is offline
post #15 of 19 (permalink) Old Sep 12th, 10, 02:45 AM Thread Starter
Giorgio
The Parkbrake was set and a friend of mine shifted the automatic gear.
