Overvolting overamping alternator - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 4th, 10, 08:16 AM Thread Starter
Timothy
This may be a stupid question but as a mechanic I learn as I experience things. We had a battery and alternator die simultaneously. The car has over 100k. The battery was 2 yrs old.
I replaced both at autozone and the wife was off and running again. About 3 weeks later she calls me and says the car wont start. So I go out to her and try to jump the car but the alternator is not putting out enough juice to keep it running.
The next day I look at the alternator and there are signs of overheating. I take it back and they give me a replacement. But Im afraid that ive just killed 2 alternators and I may fry this one too. This time I measure the output at the battery and it was up to 20+ volts and climbing! Needless to say, Yikes!
I read possible causes could be a bad connection somewhere or short in the main power wire from the alt and Im gearing up to start tracing wires. As Im disconnecting the battery I notice the negative terminal seems a little crusty so I wire brush it. Also with those little pads they sold me it wasnt sitting down all the way on the terminal and may have been loose. After fixing this im now getting 14v at the battery.
So my question, can a loose/dirty negative battery clamp cause an alternator to run at 100% and kill it?
My 69 RS/SS 396 Project -
"I may be dumb but I aint stupid"
Microgiant is offline
post #2 of 6 (permalink) Old Sep 4th, 10, 09:51 AM Thread Starter
Timothy
Re: Overvolting overamping alternator
I found troubleshooting steps for alternators and it stated that for a high reading the likely cause is a loose/dirty neg battery cable. When people tell you this can cause problems they mean EXPENSIVE problems. Another lesson learned the hard way as I rarely (edit: never) cleaned those. I just hope that there are no more problems.
post #3 of 6 (permalink) Old Sep 4th, 10, 01:27 PM
Steps
Dirty, corroded connection in and elecrical system will cause blubs to blow, even slow over time, starting problems....damn near any connection thats poor will cause problems, so why would one A55-U & ME not with the alternator?
Replacing anything it is a matter of routine to clean/replace connections, threads what ever. If not one can garantee Murhpy will step in at the worst moment a screw you up.
Murphy is your best friend...if you listen to him.
Steptoe is offline
post #4 of 6 (permalink) Old Sep 5th, 10, 04:49 AM
Harry
dawg's Avatar
Im assuming its on a 69 camaro?
if so bad regulator!
get an electronic one!
434 stroker
US Navy retired
dawg is offline
post #5 of 6 (permalink) Old Sep 5th, 10, 04:56 AM
What kind of car? Modern cars alternators are controlled by the PCM (powertrain control module) the voltage regulator inside the alternator is suppossed to limit voltage to 15.1V but a problem with the PCM can cause voltages to go higher. If I pull a certain fuse in my car I can get voltages up into the 17s.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 6 (permalink) Old Sep 5th, 10, 06:54 AM Thread Starter
Timothy
This was a 2001 Camry.
