White smoke - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 15th, 10, 09:18 AM Thread Starter
White smoke
68 Camaro Z-28 302 4 speed manual trans
Holley Performance 4150 750 4-barrel
The car starts and idles fine, 850 rpm idle w/ 28 degree advance
The smoke appears out of both pipes only after the car heats up, and while at idle--at a light or stop. The smoke appears to be of a white color w/ a small smell of oil. The car was taken to a "carb" guy who claims the carb is fine--he didn't check the jets nor do I know the jet sizes.
I replaced the plugs, rotor and cap. 6 out of 8 plugs were wet w/ fuel and carbon. After replacing the plugs, the car runs good. yet still gets the smoke out of the tail pipes. When you accelerate the "smoke" completely disappears.
indpthwill is offline
post #2 of 6 (permalink) Old Sep 15th, 10, 03:02 PM
Kev
Re: White smoke
Are you implying you want to know what the smoke is, or how to make it stop, or something else? Maybe you could ask a question?
These are the general indications from the exhaust color:
White = coolant
Blue = oil
Black = fuel (running rich)
67sc is online now
post #3 of 6 (permalink) Old Sep 15th, 10, 03:04 PM
Steps
Re: White smoke
How many miles on the engine?
Go down to the local workshop and get them to check the radiator for hydrocarbons..takes 5 mins and most do it for free.
Mark the spark plugs in the engine so when you plull them out u know which way the sat in the head....black on the top valve guides, black on the bottom rings, and if 1 is very clean compared to the others, suspect head gasket on the cylinder.
While running, pull the oil filler cap off, put your hand over, you should feel a little pressure /pulse, but if quite a bit rings
When the car sits over night or for a reasonable period during the day, then fire up, have someone check there is not a big puff of smoke come out then clear...valve guides.
With that sort of redulous advance on a street car , you Emissions...NOx etc are going to be real high, and firing before the piston gets to the top loading the engine at idle and cruising insosently down the highway.....slow death of an engine....if you have modern heads on , more efficent burn in chambers th death will be a little advanced...if compression is tweeaked up, then even faster still.
And it will not be long before the starter motor stops working when the engine is hot because it loads the armiture way too hot, and causes dry joints in it...
Steptoe is offline
post #4 of 6 (permalink) Old Sep 15th, 10, 03:21 PM
Re: White smoke
....man, that's DEPRESSING.....
BPOS is offline
post #5 of 6 (permalink) Old Sep 16th, 10, 08:13 AM Thread Starter
Re: White smoke
Wow: Steptoe: way to confusing, but thanks for the info--I think.
SC: thanks much simplier.
As for the timing any less the the 28 degree and the engine "putters" way to much--it doesn't like a lower degree.
I'm leaning towards coolant issues--head gasket.
post #6 of 6 (permalink) Old Sep 16th, 10, 04:06 PM
Steps
Re: White smoke
If an engine has hi duration 'track' cam , huge carb, they are not designed to be efficient at low rpm (unlike EFi injection, computer maintained)....notice in the pits how engines have hi rpms? and often they have locked curves cause 99% of the time the are hard out...and they dont let idle for long.
If its not because of over cam/carbed for the appilcation..it is things like power valves , sec butterfly settings.
So a rough idle with a track engine on the street is the 'penaly' for doing so, or over advancing and slow death of components..its an individual choice really.
Steptoe is offline
