What's up with the wipers - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 19th, 10, 06:30 PM Thread Starter
Cal
I drove my 68Z in the rain yesterday for the first time in years. When I turned on the wipers the squirters came on. I tried the wipers a couple of more times and the same thing happened. I have a hunch it's the switch giving me the problem....any ideas before I tear into it? Thanks in advance.
ZAPPER
1966 L72 2 door post Biscayne bench seat M21 4.10, 16K miles
1968 Z28 RS cowl plenum M21 3.73, fresh 302MO stored 450hp 355/Tremec TKO
1970 SS350 Nova daily driver bench seat M21 replaced with a Tremec TKO
1949 Meteor Pro Street 468/4L80E
1955 Chevy Gasser BBC M22 410's
ZAPPER68 is offline
post #2 of 5 (permalink) Old Sep 20th, 10, 04:08 AM
Kevin
KevinW's Avatar
Re: What's up with the wipers
1st pull the connector off the pump. Then test the connector with a light bulb (1 lead in each wire). Do you get 12v with wipers running? If not, then your pump's soleniod thing is stuck/broken. If you do, then there is something wrong with the wiring. Wipers get 12v all the time and the switch controls the ground. One wire on the switch is the ground path for the washers and should not complete the ground path unless it is pressed for washer.
Kevin
KevinW is offline
post #3 of 5 (permalink) Old Sep 20th, 10, 11:57 AM Thread Starter
Cal
Hi Kevin;
Thanks...I'll start trouble shooting in the next day or so. I appreciate your time.
Regards
Cal
ZAPPER68 is offline
post #4 of 5 (permalink) Old Sep 20th, 10, 02:06 PM
Steps
When you take the cover off inside there is a cam, this get worn and doesnt always turn on or off when its meant to.....mechanical.
Steptoe is offline
post #5 of 5 (permalink) Old Sep 20th, 10, 07:15 PM Thread Starter
Cal
Hi Guys,
I have had the cover off and it looks like its .....mechanical.
Thanks for your help, new parts on the way.
Regards
Cal
ZAPPER68 is offline
