Starting Troubles - Help Please - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 14th, 10, 02:32 PM Thread Starter
Apprentice
Having some starting troubles on my 68 SBC - 327
I have had starter problems for past 2 years... After the car warmed up, I got the dreaded "click" sound...(car has headers).. so I installed a brand new mini starter a few months back in hopes of solving the problem. With the new starter I also installed a heat shield.. I also cleaned up connections to starter, The car has a brand new battery and new wires to battery...
The car often, particularly when warm, starts strangely... Super Slow, stalling cranks, sometimes, just clicks... but after a few tries it cranks over perfectly... i captured a minor example on video.. in the video, the first start is "weird" then it cranks right over.. any advice would be helpful.. Thanks
mikeklumpp is offline
post #2 of 12 (permalink) Old Nov 14th, 10, 03:39 PM
Dan Ensign
Re: Starting Troubles - Help Please
Have you tried replacing the ground cable from the battery to the engine?
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #3 of 12 (permalink) Old Nov 14th, 10, 04:31 PM
Is your timing set correctly? If it's too far advanced, it will sound like a bad starter.
reelknots is offline
post #4 of 12 (permalink) Old Nov 14th, 10, 04:48 PM Thread Starter
Apprentice
The timing is advanced a bit.. i believe 8 degrees... timing will be adjusted tomorrow.. If it is the timing, would the starter problems be intermittent and only happen when cars hot?
The ground on the battery is new..
Thanks for the input
post #5 of 12 (permalink) Old Nov 14th, 10, 05:20 PM
Timing problem would be more pronounced when the engine is hot. 8 degrees of initial timing is not alot though. But give it a try, nothing to lose.
post #6 of 12 (permalink) Old Nov 14th, 10, 05:54 PM
Min cable size should be 1 AWG and ground tied to the block.
Battery may also be too small and not be able to generate enough current during the start action. A battery reading across posts during start/cranking of 9.5 volts will be a good indication.
Could also be not enough charging voltage to replenish battery, especially true if mechanical regulator is still installed.
post #7 of 12 (permalink) Old Nov 15th, 10, 07:27 AM
Russ
When the motor warms up the resistance increases in the starting circuit and a poor ground becomes an intermittent ground.
1. Replace ground cable from battery to motor.
2. If missing, replace ground straps from motor to chassis.
3. If anal like me, install additional ground large ground cable from chassis to motor.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #8 of 12 (permalink) Old Nov 15th, 10, 11:31 AM
Steps
Also very similar is if you do a lot of short trips as I do...most are less than 2 miles, and cold starts...once a month I put the car on the battery charger
And do any of the cables or connections get hot?
Steptoe is offline
post #9 of 12 (permalink) Old Nov 15th, 10, 12:22 PM
Larry
larryh56's Avatar
I would start there. If you have small cables they need to be upgraded anyway. I made my own from 1 AWG bulk cable from NAPA. Autozone has Duralast Gold in larger sizes that are pre-made.
Steps' question above is a good one - if the cables get hot they are either too small or there is a bad connection.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #10 of 12 (permalink) Old Nov 15th, 10, 12:39 PM Thread Starter
Apprentice
Thanks for all of the input. I will look into everything said, and keep you posted..
Yes, I take many short trips.. just charged the battery this morning and it took a good charge..
post #11 of 12 (permalink) Old Nov 17th, 10, 03:48 AM
Harry
dawg's Avatar
I had similar issue traced back to el cheapo battery cables.
434 stroker
US Navy retired
dawg is offline
post #12 of 12 (permalink) Old Nov 22nd, 10, 12:26 PM Thread Starter
Apprentice
update.. I regrounded everything and charged my
Battery.. So far so good. Thanks
