Oil on top of intake - Team Camaro Tech
post #1 of 29 (permalink) Old Dec 6th, 10, 07:53 AM Thread Starter
ZaCamaro69's Avatar
I just noticed a tablespoon-sized deposit of oil on top of my intake manifold, on the driver's side, right underneath the carb. I can't find any other oily spots.
Any ideas where this might have come from and how to fix it?
Thanks.
ZaCamaro69 is offline
post #2 of 29 (permalink) Old Dec 6th, 10, 08:42 AM
Re: Oil on top of intake
Pretty common. The bolts in the center of the intake manifold are exposed to the oil splashing around in the lifter valley, and it wicks its way up the threads. Clean up the mess, pull the bolts one at a time, clean the threads well and use thread sealant on them, reinstall.
BPOS is offline
post #3 of 29 (permalink) Old Dec 6th, 10, 09:33 AM Thread Starter
ZaCamaro69's Avatar
Thanks, Al. I'll try that out and report back.
I just ran it pretty hard around the block a couple of times, and it produced quite a bit more oil afterwards -- on both sides of the intake this time. After letting it sit for a few minutes, the oil actually seeped back in (to somewhere).
post #4 of 29 (permalink) Old Dec 6th, 10, 11:10 AM
Harry
dawg's Avatar
gasket on the distributor might do it aswell.
434 stroker
US Navy retired
dawg is offline
post #5 of 29 (permalink) Old Dec 7th, 10, 07:32 PM
on most BB and i would suppose SB, you can loose part of the head gasket seal around that area of the head and the oil will then come up around the bolt or from that cavity on the head. you don't have to loose compression and don't have to have anit freez/oil mix. the motor can run find and still have to replace the head gaskets to stop the oil. 454, did twice, 305 ho was like that when i got rid of it. both run fine etc. it will get worse. (take the time to put thin gaskets and up your compression a little, good for a dozen more horses)
just a good guess. Mike
mikess68 is offline
post #6 of 29 (permalink) Old Dec 7th, 10, 09:38 PM
Steps
Thread sealer on head bolts water pump bolts, fuel pump, and valley cover bolts...std proceedure.
Steptoe is offline
post #7 of 29 (permalink) Old Dec 7th, 10, 10:58 PM Thread Starter
ZaCamaro69's Avatar
Crapola. This is all completely new to me. I don't know what I thought was involved, but, having run a few searches, found this is not going to be a quick fix.
I'm willing to give it a go (b/c I can't afford to pay someone to do it at the moment), but can I run some of that Steel Seal crap through it for a temporary fix, or am I asking for trouble there? Don't want to half-*** this, but it'll be at least 3 weeks before I can take on this project. I just had a 700r4 installed and I'm terrified of just jacking with the TV cable. So, breaking down the entire engine is going to be a looooong process for me.
post #8 of 29 (permalink) Old Dec 7th, 10, 11:25 PM
Who said anything about tearing the engine apart? Your problem is very common with the center 4 intake bolts on a small block. My old 307 did it. Remove a bolt, wire wheel the threads, apply some thread sealer, and reinstall the bolt. Then go on to the next one. It shouldn't take more than about a half an hour. I use Permatex Aviation Form-a-Gasket, but any decent thread sealant will do.
If that doesn't solve your problem I'd be surprised. If it doesn't, then you can start pulling your hair out.
Edit - looks like it's all bolts but the 4 corners that this can happen to.
https://www.camaros.net/forums/showth...ght=oil+intake
BPOS is offline
post #9 of 29 (permalink) Old Dec 7th, 10, 11:42 PM Thread Starter
ZaCamaro69's Avatar
OOOhhhhh! Well, that's certainly a lot less intimidating.
I guess I read the comments about head bolts and immediately thought that they had to be addressed, too. Lord all mighty I'm glad I posted again.
OK, Al: promise I'm going to let this rest till I get a chance to do the intake bolts. I'll let you know how it turns out. THANKS!
post #10 of 29 (permalink) Old Dec 8th, 10, 11:24 AM
Steps
Dont take thing out of context.
NO
Back off each of the bolts 1/2 turn at a time, starting with the center and going diagonally from each side till most of the torque pressure comes off the calley cover.
Or put another way, the reverse or of the torquind down order
Then pull each bolt clean up drop on locktite thread searer, replace each bolt and TOQUE back down in the correct order with a torgue wrench.
As mentioned 20 mins to 1/2 hr job.
Steptoe is offline
post #11 of 29 (permalink) Old Dec 8th, 10, 11:56 AM
Originally Posted by Steptoe View Post
NO
YES Don't be silly. If you were adding a bracket that attaches with one intake bolt would you loosen all of them? Of course you wouldn't.
BPOS is offline
post #12 of 29 (permalink) Old Dec 8th, 10, 12:32 PM Thread Starter
ZaCamaro69's Avatar
"NO"
"YES"
Aw, man... Anyone want to cast the deciding vote?
post #13 of 29 (permalink) Old Dec 8th, 10, 02:46 PM
Mine did this for the past 3 years. This summer I pulled the center four bolts one at a time, cleaned each and put some RTV around each. No leaks since then.
Melrose RS is offline
post #14 of 29 (permalink) Old Dec 8th, 10, 06:00 PM Thread Starter
ZaCamaro69's Avatar
That sounds like a tie-breaker to me!
Steps, Al, Tom, I really do appreciate the advice. I'll report back this weekend.
Zac
post #15 of 29 (permalink) Old Dec 8th, 10, 06:20 PM
I would remove one bolt, clean it, put on thread sealer and then install it to the proper torque. Then move to the next bolt. There's less chance of distorting the manifold this way. JMO
reelknots is offline
