2002 Dodge Dakota 4.7 wont start after running - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 11th, 10, 02:47 PM Thread Starter
jsouthco68camaro's Avatar
We are in Minnesota and have a blizzsrd today, 15 " snd counting... We took our truck out to do some shopping and while the truck was warming up in randomly shut off. We went out and started it right back up. We drove to the gas station, filled with gas and then would nto start. We verifed the FP was humming when we first went to start , yet all it would do it turn over but not fire up. After sitting for 1/2 hour I went back to it and it started right up. We drove home and it ran fine. Once we shut it off, it will not start again until we wait 1/2 hour or so. The truck does not show any other signs of trouble- not over heating, runs fine when running , etc....
Any thoughts?
1968 Camaro
350 / 4 spd
Then.....
Now....
jsouthco68camaro is offline
post #2 of 7 (permalink) Old Dec 11th, 10, 03:43 PM
Tony B
Re: 2002 Dodge Dakota 4.7 wont start after running
Sounds like a coil to me.. when they get hot, they tend to shut off.. Heres a way to check.. run it till it gets good and hot.. then turn it off, then try to start it. if no start yank a plug ASAP! (caution as it will be hot) then check to see if your getting fire... if so then it may be a weak spark.. thats where id start as you see, to be getting fuel pressure. It may be low pressure too as a line may be clogged. Hope this helps...
69Z28/SS396 is offline
post #3 of 7 (permalink) Old Dec 11th, 10, 04:02 PM Thread Starter
This truck (4.7) has individual coils that sit above the plugs and fire the plugs. I thought coil too at first but am confused as to how this could be seeing each cylinder has its own coil. I would think if one were bad it would still start but would run rough. I am not too familiar with this truck and any firther thoughts would be appreciated.
1968 Camaro
350 / 4 spd
Then.....
Now....
post #4 of 7 (permalink) Old Dec 11th, 10, 06:50 PM
Dan Ensign
Sounds like a bad crank sensor.
Dan E.
69 SS396 4spd 4.10 posi. x66 coupe
Dan E. is offline
post #5 of 7 (permalink) Old Dec 11th, 10, 08:08 PM Thread Starter
I had a friend suggest that the ASD (Auto shutdown relay) may be bad. This relay apparently controls the power to the coils as well as the injectors. We wil be looking at it again in the morning.
Thanks for the suggestions guys!
1968 Camaro
350 / 4 spd
Then.....
Now....
post #6 of 7 (permalink) Old Dec 11th, 10, 08:13 PM
Joel
joels's Avatar
Because its a Dodge Any kidding, I just turned in a Company truck 2002 1/2 ton @ 345,000 miles and I did all but the first 26,000. I only had to replace a head gasket because I let one of my workers drive it from NC and they run it hot. It is still in use but only local work. I know this had nothing to do with your post but when you said the D word I had to reply
joels is offline
post #7 of 7 (permalink) Old Dec 14th, 10, 06:06 AM
Chuck
Check for DTC's before doing any other guess work on an OBD ll controlled vehicle. Maybe consult someone who works on those all the time, if it is a common problem, they should know the quick fix.
Chuck is offline
