Blue Wire - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 27th, 10, 08:25 PM Thread Starter
Wayne
Blue Wire
I pruchased a new engine wiring harness for my Z and I have all the wires plugged up correct, except for a blue wire with a black rubber cover on it with a female terminal end inside of it.
It comes out right before the wiring harness starts into the wiring gutter on the firewall, going towards the passenger side.
I think it's the Tach wire, but does it go to the neg side of the coil or where?
Thanks in advance!
1969.02dx33 is offline
post #2 of 9 (permalink) Old Dec 27th, 10, 10:26 PM
Larry
larryh56's Avatar
Re: Blue Wire
If it is the tach wire it does go to the neg side of the coil. What brand of harness do you have? I have a Painless and the tach wire is purple with a white stripe.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #3 of 9 (permalink) Old Dec 27th, 10, 10:34 PM Thread Starter
Wayne
Re: Blue Wire
It is one from eBay. . I had an orange heater motor wire, 2 plugs for the wiper setup, and a hot and ground to my coil there along with the BLUE wire. . .has to be the tach? But I have a non-original coil. Or do they have the male terminal end on the neg post on the coil? I have yet to see one on the coil.
post #4 of 9 (permalink) Old Dec 27th, 10, 10:40 PM Thread Starter
Wayne
Re: Blue Wire
Also, did the 302 have a "low oil" indicator on it? My dad said that could be what it is.
post #5 of 9 (permalink) Old Dec 28th, 10, 04:34 AM
Matt
Re: Blue Wire
Sounds like the sender wire for the oil pressure switch for the idiot lights.Is the harness you purchased for a car with or without gauges?If you have a non-gauge harness,there will be a blue wire with a rubber boot on it concealing a female spade connector.The wire would route to the sending unit location on the top of the block behind the edge of the intake manifold by the distributor.This is also the same location that the oil line fitting would thread into if you had factory gauges.Hope this info helps.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #6 of 9 (permalink) Old Dec 28th, 10, 06:41 PM
Jeff
yellow69RS's Avatar
Re: Blue Wire
Color code and location are correct for oil pressure sending unit located next to distributer.
Jeff
yellow69RS is offline
post #7 of 9 (permalink) Old Dec 28th, 10, 10:11 PM Thread Starter
Wayne
Re: Blue Wire
My Engine Harness is for gauges. . It's an X33 Z28 that we're restoring. . I am going to upload pics, sooner or later. .
post #8 of 9 (permalink) Old Dec 28th, 10, 10:23 PM Thread Starter
Wayne
Re: Blue Wire
Sorry, it's suppose to be in the headlight harness and yes, my harness was "69 w/ gauges" and I purchased it from Heartbeat City.
post #9 of 9 (permalink) Old Dec 29th, 10, 12:22 PM
Fred
Re: Blue Wire
Wayne, that'll cost ya two lashes with a wet coil wire. Hooked up and running of course.
128.79mph 1.428 60'
Fred Ficarra is offline
