Transmission clicking/knocking - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 3rd, 11, 08:38 PM Thread Starter
Jerod
I have a automatic 2001 V6 Camaro and there is a loud clicking/knocking sound when I accelerate. It sounds like it is coming from the transmission. Another thing is it only happens in the colder weather. Anyone ever have this problem or have any ideas?
2001 3.8L Camaro
jpell48 is offline
post #2 of 13 (permalink) Old Jan 3rd, 11, 09:56 PM
Fred
Re: Transmission clicking/knocking
Bad U joint?
Cold weather in Florida? Well, yeah.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 13 (permalink) Old Jan 4th, 11, 11:42 AM Thread Starter
Jerod
Currently stationed in Idaho.
Could a bad u joint cause clicking? Are there any ways to tell if its bad?
2001 3.8L Camaro
jpell48 is offline
post #4 of 13 (permalink) Old Jan 6th, 11, 01:00 PM
Fred
Easy. Crawl under the car, grab the drive shaft and wiggle it. There should be no slop. You'll be able to see it easily if either joint has failed.
128.79mph 1.428 60'
post #5 of 13 (permalink) Old Jan 6th, 11, 01:09 PM Thread Starter
Jerod
No movement.
2001 3.8L Camaro
jpell48 is offline
post #6 of 13 (permalink) Old Jan 6th, 11, 01:32 PM
Matt
Does the clunk sound come on when you take your foot of the gas under decent load...ie, if you're going 20 mph in 1st or 2nd and goose a bit and then letup, do year hear the clunk?
Matt
zlek131 is offline
post #7 of 13 (permalink) Old Jan 6th, 11, 01:39 PM
Matt
Or does it clunk when you downshift - like it does in this video when this 700R4 is downshifted from 4th to 3rd multiple times
http://www.mattlekawa.com/pictures/c...trnasClunk.wmv
Matt
zlek131 is offline
post #8 of 13 (permalink) Old Jan 6th, 11, 01:51 PM Thread Starter
Jerod
When its in park it has a slight clicking, either getting on it or just barely accelerating the clicking is louder. And yes, it still does it if i'm going 20 and get on it.
2001 3.8L Camaro
jpell48 is offline
post #9 of 13 (permalink) Old Jan 6th, 11, 01:58 PM
Matt
Good news it should not be your crank thrust bearing (that's what my issue was) as you should not hear it when in park....
Matt
zlek131 is offline
post #10 of 13 (permalink) Old Jan 6th, 11, 02:07 PM
Fred
When it's in park, engine running, how much time between clicks? Ten times a second? Once every ten seconds? Dull click or sharp tinkle?
128.79mph 1.428 60'
post #11 of 13 (permalink) Old Jan 6th, 11, 02:27 PM
Ken
Check the flex plate for loose bolts. Also check to see if it is cracked around the crank bolts.
camaro67-rallysport is offline
post #12 of 13 (permalink) Old Jan 9th, 11, 01:30 PM
I was thinking flex plate bolts as well. Oh, by the way, it was sleeting here about an hour ago. Looking at low 20's mon/tue night. Ya, it still gets a cold in FL. Good thing is it will likely be 60-70 within a week. Let us know what you find with the flexplate bolts.
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #13 of 13 (permalink) Old Feb 3rd, 11, 04:41 PM
Fred
Bump.
Drat, we lost him.
128.79mph 1.428 60'
