engine surge - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 13th, 11, 03:11 AM Thread Starter
francis
engine surge
Well my problem apart from water in the gas ended up to be a coil stuffing out and overheating the ignition wire, my only remaining problem is an ocassional engine surge usually underload not there all the time but seems to be when engine is hot, apart from checking all the electrics and re-adjusting the gap in one set of points in the mallory I have cleaned fuel filters and adjusted carb floats, is there something I have missed?
twistercamaro is offline
post #2 of 5 (permalink) Old Jan 13th, 11, 03:26 AM
Re: engine surge
I would suggest take a sample of fuel in a jar and let it set to see what settles out.
Another suggestion is to increase initial timing alittle. You can always double the book value.
post #3 of 5 (permalink) Old Jan 13th, 11, 12:21 PM Thread Starter
francis
Re: engine surge
Hi my friend thanks for that, have done the petrol sample thing appears clear and timing is set at 2-4 degrees above normal tending to lean towards maybe electrian may have slightly fouled a plug owing to the fact that he's not used to the car and inital start up habits.
post #4 of 5 (permalink) Old Jan 14th, 11, 06:31 AM
Chuck
Re: engine surge
Vacuum advance? Try pinching it off and see what happens.
Chuck is offline
post #5 of 5 (permalink) Old Jan 14th, 11, 11:04 PM Thread Starter
francis
Re: engine surge
Thanks Chuck, no vacuum advance mechanical twin point Mallory distributor, one set of points had closed slightly and bit of debris in the fuel cleanded filters, adjusted points and run for the last two days things seem to be settling down, next step venture a bit further out. Thanks again!
