cutting out at take off - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 2nd, 11, 02:53 PM Thread Starter
Chris
Cool cutting out at take off
Hello my son has a 92 Chevrolet. Full-size 5.7 Yea it idles fine but then give it a little gas and it dies
I'm not sure wat it can be Thanks for any kind of input
Muscle cars were loud, proud, and in your face, and did not pretend to be anything else.
69camarofast is offline
post #2 of 5 (permalink) Old Feb 14th, 11, 12:57 PM
Send a message via AIM to joyride_
Re: cutting out at take off
I'd clean the maf sensor? if it has one, how old/dirty is the air filter? coolant temp sensor? fuel filter? throttle position sensor?
MY RIDE
01 S10 Xtreme 2/3 drop, BUILT 4.3L v6, 5spd
DADS RIDE
69 Camaro 500+ hp 355, t400, currie ford 9inch 4.56 gears, 100 shot
joyride_ is offline
post #3 of 5 (permalink) Old Feb 14th, 11, 01:30 PM
george
Weak spring inside the egr valve.Opens to quickly and dilutes the intake charge.try operating it with the vac source removed and plugged off.
Just something else for you try at no cost for now.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #4 of 5 (permalink) Old Feb 15th, 11, 08:38 AM
Edm
Ed
The throttle body gaskets are notorious for leaking. I'd check those first.
Edm is offline
post #5 of 5 (permalink) Old Feb 15th, 11, 08:34 PM
darrell
chek fuel pressure, and fuel filter probably pump issue
97Z4C is offline
