auto trans lines - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 5th, 11, 11:03 AM Thread Starter
dave
auto trans lines
i think i seen this post on here before , is this right the bottom line from the trans to the top of the radiator out the bottom of the radiator to the top of the cooler out the bottom of the cooler to the top of the trans.
dave67707385 is offline
post #2 of 5 (permalink) Old Feb 5th, 11, 12:23 PM
Re: auto trans lines
The radiator cooler should fill from the bottom fitting. http://www.tciauto.com/Products/Tech...r_fittings.asp
BPOS is offline
post #3 of 5 (permalink) Old Feb 6th, 11, 03:47 AM Thread Starter
dave
if the lines were reversed would it be a problem with the trans? say like over heating.
post #4 of 5 (permalink) Old Feb 6th, 11, 04:20 AM
Kevin
KevinW's Avatar
Yes, overheating could be an issue. The line configurations depend on the trans model as well. You need to find the output line on the trans and match it with the lower connection on the rad like Al said. That way the cooler fills from the bottom up avoiding voids and stays in the rad longer to cool/heat the fluid. You also want to make sure your antifreeze temp is within specs. If you engine is running hot, your trans will too!
Kevin
KevinW is offline
post #5 of 5 (permalink) Old Feb 6th, 11, 12:23 PM Thread Starter
dave
thanks for the info
