97 3.8 start issues - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 5th, 11, 01:55 PM Thread Starter
Pacco
Angry 97 3.8 start issues
My car recently will not function when the temps are cold. The OBD system is not even accessable through the port. When it warms us the car will start, and the computer shows no trouble codes. I tried to warm the ECM and get it to work, but that was not successful. Is there anyone who has experienced this before? It must be a module inside the cab that is malfunctioning when cold. I cannot just start replacing every control module in the car. It will crank, but not fire or have fuel pressure.
[email protected]
Finley1006 is offline
post #2 of 9 (permalink) Old Feb 5th, 11, 02:59 PM Thread Starter
Pacco
Re: 97 3.8 start issues
I went out this morning (25 deg outside) and no start. I went out just now, ( 55 deg outside) it fires right up. angin, no trouble codes. Smokes the tires off. So there is a very wierd electrical issue at hand here. I am currently trying to read the electrical schematics to follow the wiring order that could keep the ecm from communicating. That could eleminate a few modules.
post #3 of 9 (permalink) Old Feb 5th, 11, 04:10 PM
Dan Ensign
Does the engine turn over at not fire, does the check engine light turn on with the key on and engine off, if so the main relay that supplies power to the ecm may be at fault. I don't know where it is on your car though, could explain the lack of communication at the diagnostic plug.
Dan E.
69 ss396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #4 of 9 (permalink) Old Feb 5th, 11, 04:24 PM
Dan Ensign
I just checked the wiring diagram and don't see a relay for the ecm just the fuel pump, located in the front power distribution box.
Dan E.
Dan E. is offline
post #5 of 9 (permalink) Old Feb 5th, 11, 04:44 PM Thread Starter
Pacco
It cranks, but fuel relay is not engaged. It is under the drivers kick panel. When the computer decided to wake up and link to my scanner, the relay is kicking on and all is good.
post #6 of 9 (permalink) Old Feb 11th, 11, 06:58 PM Thread Starter
Pacco
I had a suggestion that there may simply be a poorly connected wire harness. I am going to tear into the dash and start opening and reconnecting plugs.
post #7 of 9 (permalink) Old Feb 11th, 11, 08:03 PM
Daniel
Check the start switch at the end of the steering colunm.
Daniel,
1969 SS-350 Camaro, Hugger Orange
2005 Black Mustang GT
FBODY is offline
post #8 of 9 (permalink) Old Feb 12th, 11, 07:26 AM
Trey Burks
My wifes Mazda Tribute will start then die unless you give it gas when its below 40* It does the same thing, when its warm outside, its fine. No trouble codes, nothing.
67 RS/SS loaded with options Granada gold AKA Christine
Im a Traditionalist when it comes to Muscle Cars
04 F150 4 door 5.4
If you are on Facebook join the group.restore that first gen camaro dont chop it up.
67goldrsss is offline
post #9 of 9 (permalink) Old Feb 12th, 11, 12:26 PM
Check the power and ground connections at the ECM when its cold and not starting, try wigging the wiring going to the computer.
Check the fuel pump relay ground from the computer, I think you will find it not there when its cold and not starting.
Would not be the first ECM I have seen dead when cold and ok once warmed up.
400bird is offline
