quick question - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 13th, 11, 01:50 PM Thread Starter
Send a message via AIM to joyride_
quick question
valve lash? How should my dad and i go about setting it on his 72 block 355? (if the motor matters)
We broke a rocker stud on my dad's camaro so we replaced the one and need to finish setting the valve lash i guess so we can fire her back up!!
I've read quite a few different ways to do it and not sure which route to go? And also, what should they be set to?
Thanks in advance...
MY RIDE
01 S10 Xtreme 2/3 drop, BUILT 4.3L v6, 5spd
DADS RIDE
69 Camaro 500+ hp 355, t400, currie ford 9inch 4.56 gears, 100 shot
joyride_ is offline
post #2 of 13 (permalink) Old Feb 13th, 11, 02:28 PM
Edm
Ed
Re: quick question
What kind of cam do you have and what kind of rockers?
Edm is offline
post #3 of 13 (permalink) Old Feb 13th, 11, 03:30 PM
Banned
Bethanne
Nashville Beth's Avatar
Re: quick question
I'm assuming you have a standard hydraulic lifter setup.
Bump the engine over and watch the intake and exhaust valve on the cylinder you want to adjust. When both valves aren't moving then they are closed and on the base circle of the cam. You may need to bump it over several times watching the valves and you can tell when they're closed.
The pushrod should be loose; you should be able to move it up and down.
Tighten down on the rocker arm as you rotate the pushrod. You should be able to feel resistance when the rocker arm touches the pushrod. Use a light touch; don't use a lot of force to turn the pushrod. Then when the slack is out, tighten 1/2 turn.
Nashville Beth is offline
post #4 of 13 (permalink) Old Feb 13th, 11, 09:31 PM
George
Re: quick question
Brian,
I'm down the street in Lakewood. I'll send you my phone number.
Need to know all the specifics on the cam.
500 horse 350? I'd like to see that.....even mostly free before 4pm to come over.
If that radical, you should have a cam card and a lot of really fancy stuff...500 horse would be a pretty big solid lifter cam, got a cam card?
Pics would be helpful
George Kettler
US ARMY Retired
o 70 Elky SOLD 9/2016
o 68 Vette 427, 4 spd ac owner 25 years
o 68 Camaro Rallye Green Vert 327/2004R/3.73
kettbo is offline
post #5 of 13 (permalink) Old Feb 13th, 11, 09:34 PM Thread Starter
Re: quick question
Uhhhhh....sorry guys I do not know the cam specs. I know it's a full roller and it has about .580 lift i think. I don't know the rockers either but I'm pretty sure they're just 1.5ers. I will see If I can drag up any receipts/engine paperwork tomorrow. Sorry I took so long to reply we stopped working on it and I forgot until now. lol.
As of right now, all the rockers are loose, because we were planning on installing a stud girdle as well. My dad said he knows what he's doing but our machinist said otherwise about what the valve lash should be set at and what not, so I just wanted to double check in here first. Thanks again! I'll get back to you guys tomorrow.
MY RIDE
DADS RIDE
joyride_ is offline
post #6 of 13 (permalink) Old Feb 13th, 11, 09:37 PM Thread Starter
Re: quick question
He cloned a car craft 520 hp 350 motor build from back in 2002 or so. We haven't had it dyno'ed yet to confirm our expectations...but soon though! lol
To be honest, he cloned their build and upp'ed the C/R, put bigger heads on it, slightly bigger carb...I guess you could say he 1 upped the car craft build. LOL. Hopefully it still falls into the right combo and makes all that power. It is fun to drive though!
MY RIDE
DADS RIDE
joyride_ is offline
post #7 of 13 (permalink) Old Feb 13th, 11, 09:49 PM
George
Re: quick question
OK, should be fun....
Give me that call tomorrow
early outing for my 2010 engine in the video below my signature. Little roller cam
George Kettler
US ARMY Retired
kettbo is offline
post #8 of 13 (permalink) Old Feb 13th, 11, 10:00 PM
Harley
wiskeesour's Avatar
Re: quick question
I WOULD LOVE LOVE LOVE TO know what the specs are on that motor....
PLEASE?
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #9 of 13 (permalink) Old Feb 13th, 11, 10:55 PM
George
Re: quick question
he's looking for receipts and a cam card....we'll be talking tomorrow.....
George Kettler
US ARMY Retired
kettbo is offline
post #10 of 13 (permalink) Old Feb 14th, 11, 12:11 PM Thread Starter
Re: quick question
http://www.carcraft.com/techarticles...ine/index.html
It was based off that. Except my dad has 11:1 C/R, slightly more duration on the cam, and Iron Eagle 210cc heads rather than their 195's they used on the build.
To be honest, my dad said he didn't have a cam card, just had a shop in Tacoma I guess ground a cam to his specs...which sound roughly the same as the one used in that article's build.^^^
here's a quick video of it running. open headers.
MY RIDE
DADS RIDE
joyride_ is offline
post #11 of 13 (permalink) Old Feb 16th, 11, 01:53 PM Thread Starter
Re: quick question
those are his rockers, some big bastards. we showed the machinist one and he had us bring them all in so he could grind some off because all of the rockers but one, maybe 2 were hitting...
MY RIDE
DADS RIDE
joyride_ is offline
post #12 of 13 (permalink) Old Feb 16th, 11, 02:16 PM
Steve69SS396's Avatar
Re: quick question
Here is the proper valve lash procedure for that cam.
SOLID LIFTER CAMSHAFTS
Once again, the most important part is to remember to adjust just one valve on one cylinder at a time – starting with #1 and working your way through the firing order. To begin, check the spec card that came with your cam for the correct valve lash specifications. All COMP Cams® valve lash settings are “hot” settings, but will work for initial start-up as well.
Proper adjusment of the # 1 exhaust valve.
Rotate the crankshaft by hand until the exhaust valve begins to open on the #1 cylinder, adjust the intake valve by loosening the adjusting nut slightly until you feel lash on the rocker arm. Now you can set the lash on the intake valve. Spin the intake rocker nut down with the correct thickness feeler gauge inserted between the valve stem and the tip of the rocker arm. Tighten the adjusting nut until there’s a slight drag when moving the feeler gauge. DO NOT OVERTIGHTEN. After setting the lash on the #1 cylinder intake valve, put a magic marker across the top of the rocker to assure yourself it has been adjusted. Following this procedure, carefully adjust all intake valves.
To adjust the exhaust valve, rotate the crankshaft until the intake pushrod opens the valve all the way on the #1 cylinder and then begins to close (about ˝ the way back down). With the correct feeler gauge, adjust the exhaust rocker nut using the same procedure as with the intake rocker above. Repeat for each cylinder, marking each rocker arm once it has been adjusted.
Steve69SS396 is offline
post #13 of 13 (permalink) Old Feb 23rd, 11, 01:59 PM Thread Starter
Re: quick question
Sorry I forgot to mention it's a solid roller cam...do the same rules apply to the solid lifter valve adjustment?
MY RIDE
DADS RIDE
joyride_ is offline
