Vibration over 60mph - Team Camaro Tech
post #1 of 18 (permalink) Old Feb 23rd, 11, 07:11 PM Thread Starter
Brent
HAve a 67 camaro. When I get over 60 my car has a vibration, the drivers side door and the seat will even rattle. It is rythmic though. In other words it's not a constant rattle it goes in and out. Could this be something with my driveshaft?
tbd67 is offline
post #2 of 18 (permalink) Old Feb 23rd, 11, 07:27 PM
Bill
Send a message via MSN to Orange68SS Send a message via Yahoo to Orange68SS
Re: VIbration over 60mph
Could be worn U joints, go underneath your car and turn the drive shaft by hand and check it there is any play in the U joints.
68 SS Camaro - 468 BB, Tremec 5 Speed, Wilwood Brakes, Curry 9 inch (370 gear)
Orange68SS is offline
post #3 of 18 (permalink) Old Feb 23rd, 11, 07:28 PM Thread Starter
Brent
Vibration when going over 60mph
Have a 68 camaro. When I get over about 60 I get a vibration, my passenger seat and door actually start to rattle. It is a rythmic vibration though, it goes in and out,it's not constant. Could this have something to do with my driveshaft? Ideas?
tbd67 is offline
post #4 of 18 (permalink) Old Feb 23rd, 11, 07:31 PM
Hector
Can you drive through the vibration.. Or does it start at 60 and continue to vibrate no matter how fast you go?? Do you feel the vibration in the wheel or do you feel it through your butt?? when it starts vibrating and you shift into neutral does it get better or stay the same?? Does the car pull does it track straight??
More info the better..
Speedjester is offline
post #5 of 18 (permalink) Old Feb 23rd, 11, 07:48 PM
Re: Vibration when going over 60mph
I had similar - a retubed and balanced driveshaft totally cured it. $200
BPOS is offline
post #6 of 18 (permalink) Old Feb 23rd, 11, 08:02 PM
Me too. Bring it to a driveshaft shop and they can actually spin it and tell you if it is bent or out of balance.
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #7 of 18 (permalink) Old Feb 23rd, 11, 08:37 PM
darrell
sems like i would also check driveshaft u joints first-but need to take driveshaft out and swivel u joints, when dry and wore -you will hard spot when trying to swivel them--also check play at yoke where driveshaft goes in trans, trans tail housing bushing bad or galded -a bad ground to frame can cause this
97Z4C is offline
post #8 of 18 (permalink) Old Feb 24th, 11, 12:30 AM
George
I had the same issue in my '67, turned out to be the front wheel bearings. I took it to a place near my home and at first they thought the spindles could be bad but it just ended up being the bearings. I also later replaced the U-joints but that was because the car would mke a strange sqeak or whine at slow speeds. Hope this helps
ggonzalez is offline
post #9 of 18 (permalink) Old Feb 24th, 11, 03:35 AM
Guess
HwyStarJoe's Avatar
Re: Vibration over 60mph
I merged your 2 threads Brent. No need for duplication.
HwyStarJoe is offline
post #10 of 18 (permalink) Old Feb 24th, 11, 06:57 AM Thread Starter
Brent
Okay, I'm taking it to a driveshaft shop this morning. Doesn't appear it will cost that much, regardless if it's driveshaft balance, u hints, etc. Thanks for the info guys.
tbd67 is offline
post #11 of 18 (permalink) Old Feb 24th, 11, 11:30 AM
Steps
There is a resent thread on the subject explaining a drive line and a front suspetion differnece and how to tell and lists all the things to look at
From uncenter sloted mags to checking weights on drive shaft and angles etc.
Steptoe is offline
post #12 of 18 (permalink) Old Feb 24th, 11, 04:04 PM
Jimmie-Retired
I just went through this vibration thing with my daily driver Cherokee. It has done it for quite a while but wasn't real noticeable since it rides like a truck to begin with. Turns out that I have an out of round tire. They are warrantied so it will go back to the tire shop when i get a chance.
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
post #13 of 18 (permalink) Old Aug 12th, 11, 11:26 AM
Jeff
I know this thread is a few months old but I'm hoping maybe some of you guys can help me with the exact same issue on my '69 Camaro 350...
I get a "rythmic" vibration above around 65mph. The vibration goes in and out rythmically just like tbd67 mentioned. Had the driveshaft balanced and u-joints replaced yesterday thinking that was the problem. That certainly helped with the overall ride, but I still get the rythmic vibration. Any ideas? tbd67, did balancing the driveshaft fix the vibration on your 67?
To answer Speedjester's questions... The vibration seems to smooth out around 88-90mph... Now that the driveshaft is balanced, the vibration seems to be mostly in the steering wheel... When I let off the gas at speed, I'll still get the vibration... and yes, the car tracks straight.
Any help would be much appreciated, guys! Thanks!
Jeff
'69 SS 350 conv
jeff's69 is offline
post #14 of 18 (permalink) Old Aug 12th, 11, 11:39 AM
Harry
dawg's Avatar
try the simplest fix and rebalance your wheels!!!!!!!
434 stroker
US Navy retired
dawg is offline
post #15 of 18 (permalink) Old Aug 12th, 11, 11:43 AM
Jeff
Ha! Had the wheels balanced and the alignment done. Those were the first things I tried... I should have mentioned that. Any other ideas?
Jeff
'69 SS 350 conv
jeff's69 is offline
