Carburetor Clacking Noise - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 24th, 11, 03:44 PM Thread Starter
All of a sudden, I started noticing a clicking noise when accelerating. It has become a clacking noise and I think I narrowed it down to the carburetor. Maybe clacking isn't the proper description but close enough. It's a Holley 4150 on a 69 Camaro 350 engine. It only occurs when accelerating the carburetor.
jabeyers is offline
post #2 of 9 (permalink) Old Feb 24th, 11, 04:52 PM
Re: Carburetor Clacking Noise
Sounds like your cam is going out, check your rockers, for backfireing thru carb??
john68 is offline
post #3 of 9 (permalink) Old Feb 25th, 11, 08:59 AM
Mickey
Moonpie's Avatar
A carb isn't going to click or clack unless the choke is violently flapping. Is it detonation? Retard, oops, sorry. Mentally challenge your timing a couple degrees and see if the clacking goes away.That will eliminate the detonation.
Moonpie is offline
post #4 of 9 (permalink) Old Feb 25th, 11, 03:31 PM Thread Starter
I set the timing back a bit and it seems to have resolved it but there is something else going on so troubleshooting moves forward.
jabeyers is offline
post #5 of 9 (permalink) Old Feb 26th, 11, 07:41 AM
Mickey
Moonpie's Avatar
I think you're on the right track. Good luck.
Moonpie is offline
post #6 of 9 (permalink) Old Mar 3rd, 11, 05:51 AM
Ted
Do you have a spacer between the carb and intake manifold. I'm thinking it might be gas percolating in the carb. I see you live in AZ and unlike here in IA it is probably starting to warm up there.
tgifford5 is offline
post #7 of 9 (permalink) Old Mar 26th, 11, 09:17 AM Thread Starter
Ted,
It's always warmer than IA. Left the midwest in 2002.
jabeyers is offline
post #8 of 9 (permalink) Old Mar 26th, 11, 09:20 AM Thread Starter
Turns out, there was a gasket leak at exhaust manifold causing the noise. New gasket, quiet as a mouse.
jabeyers is offline
post #9 of 9 (permalink) Old Mar 26th, 11, 09:39 AM
Alan
Much better than losing a cam!!!
alan
alanrw is offline
