Glowing exhaust - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 25th, 11, 01:04 PM Thread Starter
darrell
Glowing exhaust
my 97 camaro LT1 is glowing red after exhaust after driverside cat-seems like a miss too--is glowing red coming from a plug miss fire causing rich fuel in exhaust or injector running lean all new cats and o2 sensors
97Z4C is offline
post #2 of 6 (permalink) Old Feb 25th, 11, 03:42 PM
Roy
Re: glowing exhaust
Check the Opti-spark and wires. Check to make sure the connectors at the o2 sensors are clean, too. They sell a cleaner for that. Does the computer have any codes in it?
88 IROC-Z, 5L, 5M
98 Z28, 6M
Z28Krazy is offline
post #3 of 6 (permalink) Old Feb 27th, 11, 06:41 PM Thread Starter
darrell
Re: glowing exhaust
found a bad plug wire--doesnt seem to glowing any more but it still runs rough and has a hard code --will pull the code tommorow
97Z4C is offline
post #4 of 6 (permalink) Old Feb 27th, 11, 06:47 PM
Ron
Re: glowing exhaust
I had a 95 Z with an LT1. The CAT stopped up to the point I lost all power and my manifolds got cherry red. Your may be heading in that direction.
68 PW,PS,PB,AC,v8,2speed on column,
wolfe is offline
post #5 of 6 (permalink) Old Feb 28th, 11, 08:51 PM Thread Starter
darrell
Re: glowing exhaust
the cats are brand new magniflow cats-only on drivers side--i got other issues right now-alt stopped charging-and then i am gonna start from scratch and check codes -
97Z4C is offline
post #6 of 6 (permalink) Old Feb 28th, 11, 09:36 PM
Re: glowing exhaust
Sorry, you should type in complete thoughts.
Did you replace both cats, or just driver's side? I can' tell.
And is it glowing behind the cat in the exhaust stream? Or after cat replacement, as in started after replacing them?
Either way seems like a misfire is a sure sign of the problem and if the cats are new. By the way, they will die again quickly if you replaced them and never fixed the problem, or drive it all with this new problem.
400bird is offline
