4th gen fuel system HELP!!!!! - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 26th, 11, 09:39 AM Thread Starter
evan
I have a 95 z28 convertible. Went to start it one day and it just turns over and over. No sound from fuel pump so i replaced it, still nothing. Replaced relay...nothing. What else can I check? Any help would be greatly appreciated.
ev220 is offline
post #2 of 4 (permalink) Old Feb 26th, 11, 08:02 PM
Re: 4th gen fuel system HELP!!!!!
Get a volt meter, check the voltage at the relay.
If that car has VATS, it may be the issue.
400bird is offline
post #3 of 4 (permalink) Old Feb 27th, 11, 10:38 AM Thread Starter
evan
Checked the power at the relay, no power. Double checked all fuses. Still nada. Any ideas on how to check the VATS?
ev220 is offline
post #4 of 4 (permalink) Old Feb 27th, 11, 12:42 PM
With no input power, large red wire, you might check the connection at the starter solenoid post and the fusible link for integrity. You should be able to use a hefty jumper in f/pump socket to pass power to the f/pump to get f/pump to work, if wire harness to f/pump is good and a good ground connection at fuel pump.
Simple test for VATS, should have headlights but no crank. Wait min 3 minutes, then using the same key, engine should crank.
Everett#2390 is online now
