bleeding brakes - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 5th, 11, 07:44 AM Thread Starter
dave
bleeding brakes
i replaced the rear brake lines, now when i try to bleed the air from the line with the help from my wife pumping the brake pedel for me the air doesn't stop coming out the bleeder screw. what could be wrong? we did each wheel twenty times.
dave67707385 is offline
post #2 of 2 (permalink) Old Mar 5th, 11, 09:30 AM
Re: bleeding brakes
Between each stroke of the pedal, you may not give the MC enough time to fill up the piston area before the next stroke.
Down, up, hold for about 3 -5 seconds, down, up hold for 3-5 secs, keep until a firm pedal , then bleed. Repeat as needed on RR first then LR.
If line from front to rear replaced, it will need some time in bleeding.
If all else fails, rent a pressure bleeder.
