97 Camaro SMOG Diagnosis HC/CO/NO - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 5th, 11, 12:27 PM Thread Starter
Ramien
All,
I just acquired a 97 Camaro 3.8 v6, it has 130k miles. I took it down to the smog test station and it failed miserably...
Test M1
MPH = 15
RPM = 1463
%CO2 = 14.5
%02 = 0.6
HC(PPM) = 114 (Max should be 52)
CO% = 0.51 (Max should be 0.49)
NO(PPM) = 1551 (Max should be 424)
Test M2
MPH = 25
RPM = 1438
%CO2 = 14.5
%02 = 0.6
HC(PPM) = 113 (Max should be 36)
CO% = 0.48 (Max should be 0.46)
NO(PPM) = 1663 (Max should be 711)
I plan on changing:
Oil Change
Oil Filter
Fuel Filter
Air Filter
Spark Plugs
Spark Plug Wires
Will this help and does anyone have any other recommendations like sensors or other emission electrical that I should also check?
By the way, the car runs GREAT, it accelerates smooth and idles smooth.
Thanks!
gloveside45 is offline
post #2 of 6 (permalink) Old Mar 5th, 11, 12:44 PM
Re: 97 Camaro SMOG Diagnosis HC/CO/NO
Check engine light on? Any codes??
john68 is offline
post #3 of 6 (permalink) Old Mar 5th, 11, 12:53 PM Thread Starter
Ramien
no , no light, no codes.
post #4 of 6 (permalink) Old Mar 5th, 11, 03:11 PM
Dan Ensign
High HC and NO are usually caused by an improperly functioning EGR system. The passages may be blocked or the valve stuck closed.
Dan E.
69 ss396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #5 of 6 (permalink) Old Mar 5th, 11, 06:21 PM Thread Starter
Ramien
Dan, is there an accompanying symptom when an EGR is malfunctioning or will this only show up on a smog report? As mentioned the car runs smooth.
Thanks,
post #6 of 6 (permalink) Old Mar 10th, 11, 09:05 PM Thread Starter
Ramien
ok, changed the EGR, now I get a check engine light. I removed the IGN fuse as instructed, but the light doesnt clear. The computer code is p0147 (Heater condition - heated oxygen sensor bank sensor #3), I think???
Any idea what I should do?
