very strange fuel gauge problem - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 6th, 11, 03:20 PM Thread Starter
Eric
Angry very strange fuel gauge problem
a few years ago i took out the dash fuel gauge and installed a repro. factory tach. i put a stewart warner fuel gauge in the console along with other gauges into the autometer 4 gauge pod. everything worked great. then one day the fuel gauge got fogged up and white and started reading false.like its getting hot. sometimes it worked ok sometimes it will fog up. i started out with a new sending unit before,because the original one was bad.im under the impression that there is no resistor required with aftermarket fuel gauges ,is this correct? how can my fuel gauge do this ? it worked good off and on for quite a while. any input would really be appreciated.
L30 327 is offline
post #2 of 11 (permalink) Old Mar 6th, 11, 04:47 PM
Re: very strange fuel gauge problem
If fuel gauge is fogging up, it's condensation.
Drill a small hole in the bottom and in the top to let the gauge vent.
The holes should be behind the mounting bracket to not show from the front.
Having the dash light on, will help evaporate the condensation.
Everett#2390 is online now
post #3 of 11 (permalink) Old Mar 6th, 11, 05:37 PM Thread Starter
Eric
the gauge does not work at all since last year. think i should try a new one?
L30 327 is offline
post #4 of 11 (permalink) Old Mar 6th, 11, 05:48 PM Thread Starter
Eric
i guess my main question is ,are any of you guys that are using aftermarket fuel level gauges have resistors on them,are they needed? i think mine overheated somehow. maybe a bad gauge?
L30 327 is offline
post #5 of 11 (permalink) Old Mar 7th, 11, 03:12 AM
Might buy a replacement gauge and maybe a resistor and try it with & without.
The resistor cuts down voltage, as in a voltage divider circuit, and provides a source for the sending unit.
post #6 of 11 (permalink) Old Mar 7th, 11, 07:24 AM
prostreet69camaro's Avatar
I never have installed a resistor on aftermarket fuel guages. They usually have 3 wires on them.
+12vdc
ground
sending unit wire
prostreet69camaro is offline
post #7 of 11 (permalink) Old Mar 7th, 11, 08:54 AM
No resistor here. Autometer
BPOS is offline
post #8 of 11 (permalink) Old Mar 7th, 11, 12:17 PM
Alan
Could just be a bad gauge. I would think if it needed a resistor, the manuf. would say so. If I was manufacturing them, I would incorporate the resistor in the unit and make it plug and play-makes for much happier customers, no?
alan
alanrw is offline
post #9 of 11 (permalink) Old Mar 8th, 11, 04:24 PM
Ted
X2. Maybe the SW guage didn't like being in an Autometer pod. LOL
tgifford5 is offline
post #10 of 11 (permalink) Old Mar 8th, 11, 08:32 PM
Maybe the moisture and gauge failure are related...
If moisture got in there, it may have caused some damage to the electronics of the gauge.
But, before replacing anything, I would measure the resistance of the sending unit at the gauge.
With the tank near empty it should be near 0 ohms, half full about 45 ohms and full about 90 ohms
It thats correct, its time for a new gauge.
But I don't know Stewart Warner gauges, not sure on this resistor thing. But if it needed a resistor I would think it would have had problems and shown the wrong fuel level from day one.
400bird is offline
post #11 of 11 (permalink) Old Mar 11th, 11, 06:38 AM Thread Starter
Eric
Well, I just checked my resistance from the sender wire to ground and got 6.4 ohms, and my tank is completely full. If I have to buy another sender it will be the third one. I wonder if my sender wire isint shorting to ground somewhere?
L30 327 is offline
